gauge readings? EGT, oil pressure.. .
Old Aug 23, 2003 | 04:30 AM
r7's Avatar
r7
Default gauge readings? EGT, oil pressure.. .
what are normal egt gauge readings? on throttle, off throttle, partial, wot, boost, no boost ?
and how about oil pressure? i idle @ just under 20 psi
egt is @ about 800 @ idle, and i've seen it get up to 12 on wot/boost, cruising is @ about 1000
normal?
Old Aug 23, 2003 | 01:50 PM
r7's Avatar
r7
Default Re: gauge readings? EGT, oil pressure.. . (r7)
ttt
Old Aug 23, 2003 | 02:12 PM
raene's Avatar
Oil pressure @ idle for me = 20psi to 25psi
Oil pressure @ 3k rpm for me = 70psi to 75psi
Your EGT temp will depend on where the sensor is mounted - distance from the head.
That's all I know
Old Aug 23, 2003 | 02:21 PM
E Swift's Avatar
Default Re: gauge readings? EGT, oil pressure.. . (raene)
My EGT will get up to 1250 on cruising on the freeway for a while at higher speeds. My oil pressure stays around 75 when driving. 25-35 when sitting idle.
Old Aug 24, 2003 | 05:31 PM
r7's Avatar
r7
Default Re: gauge readings? EGT, oil pressure.. . (E Swift)
anyone else?
Old Aug 24, 2003 | 05:59 PM
Finland's Avatar
EGT
idle 700-900F
Cruising 60-65mph 1200-1250F
WOT full boost 1400-1450F
No oil pres gauge, just oil temp
Old Aug 26, 2003 | 11:30 PM
NuclearB18B's Avatar
Default Re: (acurate1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acurate1 &raquo;</TD></TR><TR><TD CLASS="quote">EGT
idle 700-900F
No oil pres gauge, just oil temp</TD></TR></TABLE>
can someone translate that to celsius?
Austin184
Dec 28, 2012 02:28 PM
soontobeboost
Jan 6, 2007 06:22 AM
Juccord
Aug 20, 2005 09:05 AM
dirtySOHC's
Sep 14, 2002 04:30 PM
