2.0 GSR slow?
Old Aug 23, 2003 | 01:15 AM
speedyonez's Avatar
Default 2.0 GSR slow?
Why am i going soooo slow???? i just came back from the track and i only hit a 14.1@100mph on streets... i mean the motor is new and needs some tunning but it put down 220whp... why am i going so slow????
Old Aug 23, 2003 | 02:17 AM
GOLDBERG's Avatar
Default Re: 2.0 GSR slow? (speedyonez)
haha very funny
Old Aug 23, 2003 | 06:12 AM
T4eg's Avatar
Default Re: 2.0 GSR slow? (GOLDBERG)
whats your 60'? Could be the driver...no offense
Old Aug 23, 2003 | 06:26 AM
PearlCrx's Avatar
are you on street tires or slicks
Old Aug 23, 2003 | 10:28 AM
all_engine's Avatar
Default Re: 2.0 GSR slow? (PearlCrx)
That MPH is kinda low
That setup should net about 105 to 107 mph on slicks !!!
The times aren't as important as the MPH...
Old Aug 23, 2003 | 12:00 PM
speedyonez's Avatar
yea well i heard between 105 and 112mph....... and the 60ft was bad it was ;ole 2.48
Old Aug 23, 2003 | 12:50 PM
91tegrals's Avatar
i saw you need too practice but im just guessing...
Old Aug 23, 2003 | 01:09 PM
speedyonez's Avatar
Old Aug 23, 2003 | 01:42 PM
10keveryday's Avatar
which track?? elevation at palmdale lowers your et by almost half a sec. also do your tires spin first through third gear?
Old Aug 23, 2003 | 01:54 PM
WAFFLES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedyonez &raquo;</TD></TR><TR><TD CLASS="quote">Why am i going soooo slow???? i just came back from the track and i only hit a 14.1@100mph on streets... i mean the motor is new and needs some tunning but it put down 220whp... why am i going so slow????</TD></TR></TABLE>
Welcome to Tulsa International Speedway...the worst race track in the world. I promise you man, the track sucks. That's why your times are off so much.
Old Aug 24, 2003 | 10:11 AM
xJ.SLOTHx's Avatar
seems like you have too much power to try and run on streets, thats for sure. with a 2.4 60ft. seems like youre just spinning the tires like none other. might want to inspect your driving technique as well. get a hold of some slicks as well.
Old Aug 24, 2003 | 12:55 PM
speedyonez's Avatar
Well i only droped the clutch at maybe 2k... and uhmm i only had 18psi in the tires... shurg.... you think this would make my MPH better?
Old Aug 24, 2003 | 01:55 PM
H25's Avatar
H25
that kind of hp should get you into the 110mph easy IF it was done right.. My customer made 206whp and ran a wopping 112mph on full radial street tires.. with a 12.9! at the same track you went to.. you got some things you need to sort out on your car.. check the compression or do a leakdown.. maybe all your exhaust valves are bent or something.. where did you dyno at btw? alot of dyno's read differently.. if it wasnt a dynojet then that actual # is not correct by industry standards..
Max-
Old Aug 24, 2003 | 02:37 PM
chris@allmotor.net's Avatar
Default Re: 2.0 GSR slow? (ian)
sounds like the new infineon raceway over here in sonoma... might be fast for nitro national 6 second cars...but not for hondas
Old Aug 24, 2003 | 05:19 PM
DOHC SOLDIER's Avatar
Default Re: 2.0 GSR slow? (chris@allmotor.net)
How much did that setup cost you??? that setup should easily be in the 12's on slicks. something just isn't right with the motor, you, or both...
Old Aug 24, 2003 | 06:27 PM
aira
Guest
Posts: n/a
Default Re: 2.0 GSR slow? (DOHC SOLDIER)
what kind of car is this motor in?
Old Aug 24, 2003 | 06:39 PM
speedyonez's Avatar
A 92 DX hatch......
Old Aug 24, 2003 | 07:31 PM
jdm_ef9's Avatar
Default Re: (speedyonez)
should be a mid 12 second car. practice launching differently. get that 60ft down to like 2.0 or 1.9. my boy pulled 1.9 60ft in his itr with street tires!!!
Old Aug 25, 2003 | 01:52 PM
stupidfast's Avatar
Default Re: (jdm_ef9)
If car is gutted it should be good for high 11s easy.. need slicks and practice your lauches.. I hit 12.7 in a 94 hatch with 189whp. On 22x8x15 MT.. And that was at 3000ft..
Old Aug 25, 2003 | 02:52 PM
GokuSSJ4's Avatar
Default Re: (stupidfast)
you need to tune the car , tuning for your set up is a most .
you will be suprise how much of a difference it makes ....
Old Aug 27, 2003 | 12:22 AM
Gerhard_001's Avatar
No offense, But if you want to complain about how slow you are look at how it is driven at the track. Get some slicks. Shift faster and get at least 1.8-1.9 60ft and see if you times are still slow, if they are then tune the car. 2.4 60ft are not that great of 60ft and you should be at least hitting a 13.8-13.9 with that 60ft. Practice, practice, practice. Remember about 70% of the race is the 60ft, 30% is shifting, unless you do not know how to shift then it could be more. Good luck the next time you go to the track.
Old Aug 27, 2003 | 11:15 AM
obd2gsr's Avatar
there's nothing wrong w/the motor.
there's nothing wrong with the car.
there is something wrong with the way you drive.
practice.
rollagti
Mar 24, 2006 08:21 AM
2kTeg
Sep 2, 2005 08:45 AM
TurbodCX
Jun 17, 2004 06:11 AM
dclsvtec
Jun 1, 2004 03:10 PM
B_1_8_hatch
Nov 9, 2003 07:06 PM
