anyone compared a g-tech pro with a true dyno test
Old Aug 22, 2003 | 07:18 PM
turbob18a1's Avatar
Default anyone compared a g-tech pro with a true dyno test
Old Aug 22, 2003 | 07:38 PM
sauceman's Avatar
Default Re: anyone compared a g-tech pro with a true dyno test (turbob18a1)
It will not give you the same numbers, since the G-Tech extrapolates hp figures based on acceleration g-forces, it will also take into account the wind drag, which the dyno doesn't do. On a G-Tech, you also need to do your testing on 0° flats, because it will influence g-force readings.
andreysibiris
Jan 28, 2006 11:59 AM
aziz93
Oct 26, 2003 02:45 PM
turbob18a1
Aug 22, 2003 09:59 PM
koy
Apr 25, 2002 08:10 AM
