JDM SIR HEADLAMPS
Are jdm sir headlamps glass or plastic? I bought me a set of plastic ones and wanted to be sure cause now I hear that the zc ones are plastic so now i'm scratchin my head on this one.
I have 2 sets of SIR headlights and one is plastic (JDM) and the other is glass (Europe). It is easy to tell if you have the SIR lamps.... the are longer than the US or ZC lamps and on both of my sets they only use 1 light bulb (H4H).
Hope this helps.
Hope this helps.
There are a few little differences. The housing for the euro spec lamps look to be a little larger (depth wise). Also on my euro lights, they have an electronic leveling system so you can adjust the beam height from inside the car or something like that. I’m not quite sure though. They do have a little motor attached to the leveling adjuster.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrueNorthStar »</TD></TR><TR><TD CLASS="quote">Also on my euro lights, they have an electronic leveling system so you can adjust the beam height from inside the car or something like that. I’m not quite sure though. They do have a little motor attached to the leveling adjuster.</TD></TR></TABLE>
damn, that must be awesome.....!!!!!!!!!!!!! someone from europe knows more about this???
JALOP B16
Jan 31, 2003 08:22 AM
