EGR problem
Old Aug 14, 2001 | 03:06 PM
acbah01's Avatar
New User
Default EGR problem
I have an 89 CRX HF and have been getting a 12 code on the ECU. I ran through the troubleshooting section from the Haynes manual I have. First problem is when I put a vacuum on the EGR valve the engine doesn't stall like it's suppose to, it only drops the idle way down. I replaced the EGR valve and still the same thing. I kept going through the check list and on the vacuum line between the air chamber and the EGR control solenoid valve I should have "approx 8 inch of vacuum" I only have 5 inch of vacuum. Everything else checks ok. the solenoid clicks when I jump it and all the voltages are correct. If anyone has a suggestion it would be great. I need to get this to work to pass emissions.
yzracer
Oct 2, 2011 04:23 AM
xyllok
Dec 29, 2010 10:41 AM
swertepinoy
Oct 12, 2009 02:50 PM
BuddhaSiR
Feb 16, 2007 04:51 AM
