Will coilovers from a 1996+ civic fit on the ITR?
Old Aug 14, 2001 | 03:05 PM
typerboy349's Avatar
Default Will coilovers from a 1996+ civic fit on the ITR?
Just wondering if the shocks from a 1996+ civic will fit on ITR's? Does anyone have a definite answer?
TIA
Jon
Old Aug 14, 2001 | 03:07 PM
sgT's Avatar
sgT
Default Re: Will coilovers from a 1996+ civic fit on the ITR? (typerboy349)
yes but if you are trying to put the civic shocks on then you must change
the itr rear lower control arm to that of a regular integra or civic.
Old Aug 14, 2001 | 04:23 PM
Default Re: Will coilovers from a 1996+ civic fit on the ITR? (sgT)
Sgt-
So will the front ones fit without a problem? Is it pretty easy to bolt the regular integra lower control arm onto the ITR chassis?
thanks for your help,
Jon
Old Aug 14, 2001 | 04:30 PM
Mike M's Avatar
Founding Member
Yes the fronts bolt right up
Old Aug 14, 2001 | 04:59 PM
Default Re: Will coilovers from a 1996+ civic fit on the ITR? (TypeRmsm)
So, my next question is "Are there any negative effects to bolting up a set of coilovers designed for a civic and using them in an ITR?"
Jon
Old Aug 14, 2001 | 05:02 PM
Big Phat R's Avatar
weight wise - i would say that the spring rates might be too low - but it depends on the coilover
yellow blur's Avatar
since the coilover is designed for the civic, idunno if its the best to put it on your integra, seeing that it is a much heavier car. also, changing your rear lower control arm to fit civic sus, its a way weaker piece.
Old Aug 14, 2001 | 06:49 PM
Default Re: Will coilovers from a 1996+ civic fit on the ITR? (yellow blur)
Well, I'm looking at a set of Tein HR's. I was wondering if there were any companies that made billet lower control arms for integras/civics?
Jon
Old Aug 14, 2001 | 06:52 PM
Mike M's Avatar
Founding Member
The HR Should be the same as the HA in that they require the ITR Rear LCA which you already have on the car
Old Aug 14, 2001 | 08:00 PM
So do you think that they will fit on the ITR without any modifications? Does Tein make a 1996+ civic specific kit that would allow the coilovers to bolt up to the civic chassis without the ITR control arms?
thanks,
Jon
Rocket_Man
Suspension & Brakes
Mar 14, 2013 07:14 PM
dillbrit
Aug 19, 2011 11:02 PM
EGed up from the seat up
Mar 9, 2009 09:35 AM
DriveSlowHomie
Suspension & Brakes
May 15, 2005 05:24 PM
DB8
Apr 13, 2004 10:44 PM
