asking the experts
I just got me a 90 HB dx, si? Dont care with a zc motor that has just been pulled out Can I install a b18 a out of a 92 integra? Will it all work out or are there some special needs I can find out about before hand. The car is for pure race.(fun) So function weighs much more than fasion , no ac ps Just engine tranny and fun...
Thanks for any advice.
here's a company that makes them.
http://www.hasport.com/
I would rather have you go buy a kit from hasport.
what year integ is it comin out of???90-91 will bolt right in(with the mounts shift linkage ecu and other mic. things) 92-93 is different because its obd-1 apose to the non-obd of the 90-91. so you will have to get a wiring harness and alot of other things, so try for the 90-91 if you can, its a little easier.
get the complete 92 teggy motor with its matching ECU, and get a conversion harness (obd0 to obd1) along with some aftermarket mounts and modified shift linkage and you should be set. As long as u have all the OBD-1 electronics, it would actually be cheaper to just buy the conversion harness, instead of gettin the obd0 ecu, dist., injectors, etc. Oh BTW, u will be using the engine harness off your civic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VashTheStampede »</TD></TR><TR><TD CLASS="quote">Yeah.. it's not that easy... haha.. The 4th gen is like a hot woman... "mysterious, but once you get her to put out, she owns you".
LMAO! I need to put that in my sig! I haven't busted her out yet; I guess I'm not too slick. Haha.
Anyways, what are you doing with the ZC?!?! Wanna sell it!?!? Hit me up if you have a good price.
</TD></TR></TABLE>LMAO! I need to put that in my sig! I haven't busted her out yet; I guess I'm not too slick. Haha.
If you're talking to me, I already have the MPFI swap, running a D15B7 with PM6. If you're talking to madhatch, he already has MPFI too if he's running a ZC. Or was. Whatever.
already running the mpfi with a zc in it, just building a car I want it to hit 13's maybe high 12's or mid to high 8's in the 8th
anybody got an a1 in one of these? I was thinking of putting it in to hold over for the swap considering all the mounts are in place from the zc. Maybe bolt up the z6 head, got a good tranny for 150 bux from an si last week
A1 won't fit without custom welded mount to front of block. The A1s mount is where the powersteering mounts up on a ZC. Just get another ZC or find an Si motor to hold you over until then.
willpower102
Dec 20, 2008 09:33 AM
the buddha
Dec 17, 2003 09:04 AM
