shims under the differential?
Old Aug 22, 2003 | 03:01 PM
mhgleitz's Avatar
Default shims under the differential?
i'm putting in my quaife diff. how do i know how many shims to put under it?
Old Aug 22, 2003 | 10:27 PM
Eddiebx's Avatar
you only use one thrust shim. But you have to select the correct thickness one to use. This is done checking the preload on the diff, and using thicker or thiner shims to get the preoload where you want it. I suggest you get a helms manual it comes with good instructions to set the preload. It's not all that hard to do, just timing consuming.
89ED
11
Sep 14, 2013 10:53 PM
efboy
Honda Motorcycles
Feb 18, 2008 06:34 PM
int3gra07
Dec 7, 2006 02:54 PM
jaygtyj
Sep 20, 2004 09:41 PM
The Punisher
Dec 4, 2001 11:58 AM
