need help putting on tranny
rapping up the job for my clutch on my civic with gsr swap and now i can't get the driver side axle or half shaft to go in all the way so i can put up the tranny back in place. please help!!!!!
try to get the hub onto the axle, and just tap the hub and/or axle with a rubber mallet while one of your friend twists the axle back and forth. It should work.
Dont hit anything was what i was told. I had the same problem on a 95 ls. You just have to push really hard. I was told you can't tap on anything except for up by where the axles go into the tranny. It is a bitch but i just pushed (for a long time) and it finally went in.
crxmadman
Mar 8, 2006 07:43 PM
