power steering
i have a 90 2 dr dx it has power steering it is lower with neuspeed race springs so its loww.I went fishing yesterday and i took off the power steering the streering feels great on tha road.i was wondering if anyone else was running there accoreds with out the power steering and if there are any benifites from this .
thanks jason
thanks jason
reduces parasitic losses on the crank, hence, lowers the amount of lost hp from the crank to the wheels. I've seen a dyno for my gen car (4th gen) which showed a 3.5hp gain from removing the belt alone. You need to drain the fluid from the system however, it'll make steering a little easier, and also it will stop anything from getting messed up.
Nathan
Nathan
Explain how you have a car that has power steering, and you remove the pump and make steering EASIER??
Isn't the rack just assisted by the hydralic pump which allows you to steer? And by removing the pump you lose the power to steer? Wouldn't you have to install a rack and pinion system in the car or are they already rack and pinion, just hydralically assisted? Please explain.
