Magnecor Plug wires...good?......price?
Old Aug 14, 2001 | 12:54 PM
andrew n's Avatar
Default Magnecor Plug wires...good?......price?
I want to replace my OEM plug wires because they are 7+ years old and have 111K on them. Are the worth the price? Anyone see them around for a good price?
Thanks!
Old Aug 14, 2001 | 01:00 PM
slowerthanu's Avatar
New User
Default Re: Magnecor Plug wires...good?......price? (andrew n)
I have Magnacores, I like them, on that note dont get them. Stick with stock or NGK's. The Magnacores are huge and floppy, they are a bitch to get to stay in and I want some NGK's anyways.
Old Aug 14, 2001 | 01:34 PM
dustin's Avatar
Default Re: Magnecor Plug wires...good?......price? (slowerthanu)
I have magnecors and I use the stock wires now. The magenecors do NOT stay on the spark plugs OR the distributor. They have come off in traffic for me many times and make me think I blew my motor or something.
Stay away from them.
Dustin
Old Aug 14, 2001 | 01:49 PM
jonsteR's Avatar
Mine acutually stays on the motor and distributor very well. But if you have a stock motor (internally) then just go with NGK or stock.
Old Aug 14, 2001 | 02:12 PM
94RedGSR's Avatar
25 Year Member
Default Re: Magnecor Plug wires...good?......price? (jonsteR)
Used the Magnecors before...good wires, not so good at staying on the distributor cap. Right now I'm using MSD wires and they fit great and haven't had any problems with them coming off or anything like that. I was able to use my stock wire separators with these so it looks factory. I would recomend these.
Old Aug 14, 2001 | 02:32 PM
Go Mifune's Avatar
New User
Default Re: Magnecor Plug wires...good?......price? (dustin)
i have magnecor 10mm r-100 (got them for $80 in 1995). you'll never see anything more ridiculous. now i know why i've seen pics of magnecors with a freakin zip ties around each dist end plug. when one pops off as you blast away from a stoplight it will scare the living **** out of you as you bog, then limp towards the edge of the road on three cylinders sounding like a vw bus with no exhaust. can't understand why the company can't seem to engineer a wire that stays on the distributor - seems like an important feature for plug wires... i've made minor adjustments that seems to help a little but i make sure i check them once a week and push them back on. maybe they fixed this eventually? when i dump these, i'm getting moroso. i think they're around $55. be aware that they don't come in black so some jack-booted thug from the anti-rice gestapo will probably lable you "ricey" as you won't be in compliance with their master list.
Old Aug 14, 2001 | 02:37 PM
redline's Avatar
Default Re: Magnecor Plug wires...good?......price? (Go Mifune)
I never had problems with them coming off but they only lasted about a year then i would have misfire problems.
I use MSD now and they are great.
k
Old Aug 14, 2001 | 04:01 PM
Rory Breaker's Avatar
I just replaced my toasted stock wires with some NGK's and was very pleased with the replenishment of performance. They dont fit PERFECTLY, but are damn close.
Ive also heard lots of problems from magnecor, and also seen some poorly fitting MSD boots.
Old Aug 14, 2001 | 06:11 PM
Halo's Avatar
Default Re: Magnecor Plug wires...good?......price? (Teken)
I just replaced my Magnecors cause they always slipped off the plugs. IMO-these wires are total crap. I have had great luck with Vitek or Nology both of these use stock style boots for a perfect fit.
Old Aug 14, 2001 | 06:40 PM
137's Avatar
137
aftermarket wires are all for show, best wires are stock ones... you want a better spark get better plugs, and an aftermarket distributor...
but wires are just for looks.
Old Aug 14, 2001 | 09:39 PM
andrew n's Avatar
Default Re: Magnecor Plug wires...good?......price? (137)
Well You guys turned my against magnecor because I dont want my crap popping off! So.... give my some info on the NGKs or MSDs. Price, which ones, Where!!!
Thanks
PS
In my GSR I went to copper plugs and am VERY pleased. However, I think my weak link may be my plugs and/or distributor.
Old Aug 14, 2001 | 09:46 PM
threatcon13's Avatar
New User
damn..i was about to get some magnecores...thanx for all the feedback. now i kno i aint gonna get those pieces of shxt....well what do u guyz think about the nologys? any feedback on them?
Old Aug 14, 2001 | 09:55 PM
New User
Default Re: Magnecor Plug wires...good?......price? (turbo01gsr)
I have zip ties around each of my magnacore wires so the stay on the dist. cap. I pound them in with the butt of a soft mallet and they tend to stay. I am gonna get some NGK's I think.
Old Aug 14, 2001 | 11:40 PM
Nology makes good wires, as theyre the only ones with built in capacitors. Also why theyre so expensive...Id try and find a used set if you could, b/c its just ridiculous to pay that much for wires.
Old Aug 15, 2001 | 08:55 AM
GSRacer's Avatar
New User
Default Re: Magnecor Plug wires...good?......price? (newgsrdriver)
i have magnecore's and they do tend to pop off once in a while. i heard that nology also suck ***. why pay more than $120 for wires??? stick with stock, mds, or ngk.
Old Aug 15, 2001 | 09:26 AM
Mike K's Avatar
Stock wires are best. They fit perfect.
I have no personal experience with Nology, but the concept doesn't really make sense. If there's already a ground for the engine, a ground on the tranny, and a ground on the thermostat housing, why would you need four more grounds coming off your plugwires?
Old Aug 15, 2001 | 09:31 AM
Go Mifune's Avatar
New User
teken, can you comment on car stereo interference rumors based on your experience with nology?
Old Aug 15, 2001 | 09:45 AM
ajbones's Avatar
New User
same, same. I got them. they fall off. I freak. I put them on again.other than that?? I would not buy them again.
Old Aug 15, 2001 | 09:53 AM
Go Mifune's Avatar
New User
Default Re: Magnecor Plug wires...good?......price? (ajbones)
here a hot tip:
make sure you shut off the engine before reattaching the magnecor plugs to the distributor unless you like playing with small bolts of lightning plus you'll feel really stupid.
Old Aug 15, 2001 | 01:32 PM
Halo's Avatar
I have Nology now and I will never go back to any other brand! I feel comfortable putting these on and NOT having to worry about any slippage. If you are mostly stock then stock wires should be fine. But if you are using an aftermarket ignition system (MSD 6AL) then the extra 5mm in wire diameter can flow more spark. If your looking for extra hp from a set of wires, good luck. The thing I noticed was an extra 5 mpg, I went from 12 miles city to 17 city and from 18 highway to 23 mpg highway. Also you will notice improved throttle response.
Old Aug 17, 2001 | 01:13 AM
FourDoorGSR's Avatar
Default Re: Magnecor Plug wires...good?......price? (Halo)
Well to throw more fuel on the fire. I also have magacor wires on my gsr. The seal is horrible around the spark plug holes. I am planning on cleaning my engine bay soon and I am really worried that water might seap its way past the magnacor wires and into the spark plug holes!!!
And yes, they did pop off on me once!
Old Aug 17, 2001 | 01:54 AM
keys's Avatar
Default Re: Magnecor Plug wires...good?......price? (FourDoorGSR)
i have magnacor wires and they never popped on me..... but geez, i don't think it really did any good either, i'd say if i were to get another set of wires i'd get NGK to match my NGK spark plugs and save money while i'm at it
JasonLSIntegra
Aug 16, 2007 07:47 PM
Elite Hatch
Jan 15, 2003 04:31 PM
civicrr
Jul 17, 2002 02:09 AM
CM-R
May 21, 2002 09:41 PM
REDSOL
May 6, 2002 10:35 AM
