obd-0b16a valve adjustment specs please help !!!!!!!!
can anyone tell me what size feeler guage is needed for a valve adjustment on a b16a.. obd 0
please include intake mm and exhaust.. i work at acura but there are no tech books here for the del sol or civic si..
do not set your valves to gsr spec..BADDDDDD !!!! TICK TICK LOL NOT GOOD !
THANKS FELLAS AND OR LADIES
BRIAN
From: I told you to wait in the truck in Texas, United States
intake 0.15-0.19mm {.006-.007}
exhaust 0.17-0.21mm {.007-.008}
If you set it to spec and it is still noisy,check the "lost motion assemblies"
It is a common problem for them to go bad.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">intake 0.15-0.19mm {.006-.007}
It is a common problem for them to go bad.</TD></TR></TABLE>
not just common, its an absolute eventuality... especially on first gens. i've yet to hear one that didn't sound like a typewriter, its always a dead giveaway to the venerable B under the hood.
Hey guys could i get more information on the "lost motion assemblies". is this the rocker arms. I've adjusted all my valves and its still ticking. where is it located. what do i have to do to fix this problem.
It is like a shock absorber for the vtec lobes rocker when it is not engaged.
see: https://honda-tech.com/zerothread?id=505867
also look at *this*
#18 in this pic if it works:
also look at *this*
do you have to remove the valve spring or retainer to be able to change the lost most assemblies.
Modified by drift2live at 4:14 AM 8/23/2003
I don't believe so. Just pull off the valvetrain assembly and they should be easily removable by using a magnet. Pop the magnet onto the top of them and pull them straight out from the head.
wagon-r
Jun 11, 2013 09:32 AM
