Rapid blinking CEL and car stuttering.
Old Aug 22, 2003 | 08:55 AM
ShagginJet's Avatar
Default Rapid blinking CEL and car stuttering.
This has been ongoing for the past several months, maybe about the last 6-8. I've already replaced the Relay and plan to replace it again just to verify that it's not the problem.
As I'm driving the CEL will start to blink rapidly, the car will stutter, and I hear the relay clicking as the light blinks. If i let of the gas for a moment it'll usually stop. In the past it's been pretty minor, but last night and today it's started acting REALLY bad. Even had it stall a couple times.
Need help guys. I'm gonna replace the O2 Sensor and Relay today, beyond that though I have no idea what else to try.
No code is given on ECU.
Modified by ShagginJet at 8:43 PM 8/22/2003
Old Aug 22, 2003 | 12:07 PM
ShagginJet's Avatar
:BUMP:
Checked price on O2 Sensor and Main Relay.
Honda O2 Snsr = $200
Main Relay = $60
?? = It should be ok to use a bosche sensor instead of the Honda one, right?
Old Aug 22, 2003 | 01:09 PM
1990hondaHF's Avatar
Default Re: (ShagginJet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShagginJet &raquo;</TD></TR><TR><TD CLASS="quote">
Honda O2 Snsr = $200</TD></TR></TABLE>
Damm son, go to Autozone! Save a few $$$'s! Cost me $17.99....
Old Aug 22, 2003 | 01:58 PM
ShagginJet's Avatar
You must have bought the sensor with leads. For $45 i can get a bosche unit with the actual plug. Gonna do that. Don't have cash right now though and the relay isn't returnable.... Not happy what so ever.
Old Aug 27, 2003 | 07:24 PM
ShagginJet's Avatar
I went out and replaced the relay... same problem.... anyone have any idea's or know of a mechanic capable of diagnosing the issue? I'm in LA over by Marina Del Ray.
My mechanic isn't 100% sure of the issue. And the first thing he wants to replace is gonna cost me about 400$.
Old Aug 27, 2003 | 07:48 PM
JonGP4's Avatar
try a know good ecu and see what happens
Old Aug 27, 2003 | 08:20 PM
ShagginJet's Avatar
Would the ECU seriously just stop working?
Old Aug 27, 2003 | 08:54 PM
JonGP4's Avatar
its know to happen, i've personaly seen 2 do it, eirther fried or just don't work at all
Old Aug 28, 2003 | 07:26 AM
ShagginJet's Avatar
Anyone in the marina are have an extra ECU i can swap just to check this out. I have a 88 HB DX Auto 1.5.
Old Aug 28, 2003 | 09:12 AM
JonGP4's Avatar
if it turns out to be bad, i have a 89 DX Auto ECU i can sell cheap
Old Aug 28, 2003 | 10:11 AM
ShagginJet's Avatar
It's not a problem to pick one up. Only issue is that I have to drive my bike out to the local junk yard. That's the pain in the ****.
Old Aug 28, 2003 | 01:44 PM
19crx90's Avatar
My crx wont start at all...dont know what seems to be the prob, check ecu no cell codes commin up....but a couple weeks ago it blink cel16 "fuel injector" and i unpluged it and now wont crank.
Old Aug 31, 2003 | 06:14 PM
seekerONE's Avatar
had similar problem...was traced to loose ground wire for ECU...that ground is on the thermostat housing
Old Aug 31, 2003 | 06:43 PM
d357r0y's Avatar
Default Re: (seekerONE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seekerONE &raquo;</TD></TR><TR><TD CLASS="quote">had similar problem...was traced to loose ground wire for ECU...that ground is on the thermostat housing</TD></TR></TABLE>
Same here.. I just had this problem yesterday and freaked out cause I thought my ECU was bad. I even went as far as to put in a spare one to test it. Anway, when I put in a new thermostat, it was getting dark and I was in a rush and missed the ground wire.. blink blink blink... tighten that bolt down!!
Old Sep 2, 2003 | 08:00 AM
ShagginJet's Avatar
Is the ECU from a std 1.5 DPFI the same as an auto 1.5 DPFI??
Where is this ground wire located??
Old Sep 2, 2003 | 02:51 PM
R6Boy69's Avatar
on the thermostat housing near where the lower rad hose connects to the motor.
Old Sep 2, 2003 | 02:58 PM
ShagginJet's Avatar
WTF. The ECU grounding is located way out there?
Old Sep 6, 2003 | 10:39 PM
ShagginJet's Avatar
So the problem has been fixed. I was pissed off Thursday, as I was looking over the car. Decided to just shake all the harnesses in the engine bay. When I got next to the one by the DPFI the car stuttered and shut off. I made sure all the plugs where tight, started the car up, shook it again, nothing.
Been driving it since, been running great. Rear disk swap goes in tomorrow, will post pictures.
nitewolf
Aug 25, 2009 02:55 AM
Ninety5Ex
Mar 1, 2005 11:05 PM
terminaloverlowd
10
Jul 27, 2004 03:12 PM
