A/C Compressor Matsushita Mounting Bolts?
Looking at the majestichonda site ....it shows the bolts on the bottom bracket what about the two top ones? I just went to the parts store and bought everything got home and realized i needed mounting bolts :D doh.
Well its says the bottom left is 8x120 and the right is 8x105 should i just get 2 of each and hope they go? Are those numbers all i need to get the bolt at the auto store?
Notice #23 and 24
Then in the helms it says "mounting bolts 25n-m" does that mean anything?
Modified by etp72 at 6:07 PM 8/22/2003
Notice #23 and 24
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by etp72 »</TD></TR><TR><TD CLASS="quote">Looking at the majestichonda site ....it shows the bolts on the bottom bracket what about the two top ones? I just went to the parts store and bought everything got home and realized i needed mounting bolts :D doh.
Well its says the bottom one is 8x120 and the other is 8x105 should i just get 2 of each and hope they go? Are those numbers all i need to get the bolt at the auto store?
Then in the helms it says "mounting bolts 25n-m" does that mean anything?</TD></TR></TABLE>
OK well first dont quote me on this but I thought all but one of the compressor bolts were the same size?? I can double check later when I go over by my car since i have the bolts and the compressor sitting there.
As for the 25n-m that means newton meters its another way of measuring torque instead of ft lbs or inch lbs. so either find out what the equivalent to 25n-m is or get a torque wrench that reads in n-m as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vinceg99 »</TD></TR><TR><TD CLASS="quote">
OK well first dont quote me on this but I thought all but one of the compressor bolts were the same size?? </TD></TR></TABLE>
Ya can you check that out and let me know? Because right now i am under the impression that the 2 on the left are the 8x105 and the 2 on the right are the 8x120.
Also what is the thread pattern? Regular?Pitch?Fine? My guess would be regular?
I went to all the stores around my area and no one carries 8mm bolts that long
and theres one bolt/nut store in the area that carries all kinds of weird sizes/shapes and it is of course closed for the day. And i dont have any Honda dealers in the area. Looks like ill have to postpone the installation till tommorow, hopefully they will be open
From: I told you to wait in the truck in Texas, United States
25Nm=18lb-ft
The bolts are 8mm X 1.25mm pitch
I *guess* you would need two of each..
What you can do is measure the width of the compressor front and rear on the top bolt hole and compair it to the width measured on the bottom bolt holes.
The bolts should probably be at least one inch longer than the width of the mount
RACEPAK
Apr 8, 2006 08:53 AM
MeanGreenEG9
Jan 10, 2003 07:15 PM
