bLOCK SAVER?
Old Aug 22, 2003 | 06:47 AM
CIVICNONVTEC's Avatar
Default bLOCK SAVER?
i heard using a block saver is a alternative if u cant afford sleeves? And Is it worth getting a block saver for a Daily NA B18c or Should i get my block Sleeve?
Old Aug 22, 2003 | 12:56 PM
Need4Boost's Avatar
Default Re: bLOCK SAVER? (CIVICNONVTEC)
It really depends on how much hp you plan on making. If you want to make over 300+hp then yes sleeve the block. But if you are just gonna use your car as a daily driver and not run much boost then a block guard should be fine.
Old Aug 23, 2003 | 06:00 AM
T4eg's Avatar
The block saver is just used to make the top of the block alittle stronger. I would 110% advise you to sleeve the block if you are you going to make anyting over 350whp. You can make more WHP than that on stock sleeves but it would be a good idea just to be safe. goodluck
chris
Rod.
Sep 12, 2003 10:51 PM
Soon_2b_evil
Aug 8, 2003 06:40 PM
madman604
May 23, 2003 04:19 PM
