Is there a difference between V6 and 4cyl springs(suspension)?
Old Aug 22, 2003 | 05:55 AM
yellaboi's Avatar
Default Is there a difference between V6 and 4cyl springs(suspension)?
I just recently ordered a set of lowering spings for 98 accord. The box says 6cyl springs. I have 4cyl is there any difference in springs? Will they even fit?
Old Aug 22, 2003 | 08:10 AM
fluxion's Avatar
amin n'rangwa edanea
Default Re: Is there a difference between V6 and 4cyl springs(suspension)? (yellaboi)
they should, but the front will probably sit a bit higher then what you'll be expecting since they're probably tuned to support the v6 accord's heavier motor.
you really should get some springs specific to your application.
Old Aug 22, 2003 | 08:14 AM
yellaboi's Avatar
Default Re: Is there a difference between V6 and 4cyl springs(suspension)? (fluxion)
yea I bought them off ebay, they are brand new but it was advertised as 98-01 accord lowering springs. I did not know there was a difference between V6 and I4 springs.
Old Aug 24, 2003 | 11:40 PM
philadd's Avatar
fluxion is correct. the springs will fit perfectly, but the front end will sit close to stock height. the v6 models are about 300 lbs heavier than the 4-cyl models, and all of that weight difference is in the front. i suggest selling the v6 springs and buying some 4-cyl springs, because you will most likely be disappointed with the results of installing the v6 springs.
Old Aug 25, 2003 | 09:55 AM
TypeSH's Avatar
Default Re: Is there a difference between V6 and 4cyl springs(suspension)? (philadd)
send them back to whoever you ordered them from
chiaxi2002
Jun 22, 2009 07:20 PM
kenttt
Suspension & Brakes
Oct 27, 2007 09:53 PM
2fast2accord98
Feb 22, 2006 04:06 PM
luv2drivecrx
Aug 21, 2005 09:55 PM
Robot Sonic
Suspension & Brakes
Apr 2, 2005 05:42 PM
