b16 swap into 91 civic hatch, problem :(
Old Aug 22, 2003 | 04:24 AM
ovrbst's Avatar
Default b16 swap into 91 civic hatch, problem :(
hey guys i just completed my swap a lil while ago but put in a nwe tranny last nite,, its an LS transmission has vss and everything like that on it
now the problem is that my vtec wont work its throwing out code 7 on the ecu which is only throttle position sensor, anyone know why vtec isnt kickin in?
i thikn it MAY be the wirring, the guy that i had to do it might have screwed up, and i still paid him 100 bux im gonna talk to him it might be that,,, is it easy to wire it up any kind of info would be great, thanks
Old Aug 22, 2003 | 05:08 AM
onetwothree's Avatar
Default Re: b16 swap into 91 civic hatch, problem :( (91_civicsi)
Well when you get a code, the motor goes into a limp mode and that could cause the vtec not to work and could also lower your redline.
Old Aug 22, 2003 | 05:12 AM
ricodemus's Avatar
Default Re: b16 swap into 91 civic hatch, problem :( (onetwothree)
did everything work before the new tranny? I was going to say, many times the TPS will get damaged or broken in motor shipment. You may just need a new one.
Old Aug 22, 2003 | 02:46 PM
ovrbst's Avatar
Default Re: b16 swap into 91 civic hatch, problem :( (ricodemus)
okay so if the tps isnt workin that could be why?
Old Aug 22, 2003 | 04:50 PM
chadmasterc's Avatar
yes, if its throwing a code then vtec wont work
Old Aug 25, 2003 | 03:06 PM
ovrbst's Avatar
Default Re: b16 swap into 91 civic hatch, problem :( (chadmasterc)
hmmm alright k thanks guys, i'll try putting in a new TPS sensor and see if that works,,, also im using a vtec activation switch to engage vtec right now basically tricking my ecu to switch the cam lobe but the fuel map doesnt change, is this damaging my engine?
Old Aug 25, 2003 | 07:18 PM
MadPJ7's Avatar
at the Hondata website they state that the VTEC and non-VTEC fuel maps differ about 10%. Unless your car is running very rich, forcing the high lift cam to engage could lean out the A/F ratio enough to cause detonation. Personally I think the MAP sensor would correct for some of this, but I'd still reccommend using the VTEC ECU.
hatch_swap
Jan 9, 2014 02:35 AM
blasterman87
Sep 16, 2009 02:34 PM
wdbdycrx
Mar 13, 2005 06:21 PM
...esteban
May 1, 2004 05:11 AM
redzcstandardhatch
Jul 27, 2003 09:39 AM
