torque specs for the valvecover bolts. help!!
Old Aug 22, 2003 | 01:59 AM
2.2L EH2's Avatar
Default torque specs for the valvecover bolts. help!!
i just re-painted my valvecover and just wanted to know what are the torque specs for the valve cover. i did a search i came up with nothing.
Old Aug 22, 2003 | 02:35 AM
Shakes's Avatar
space cadet
Default Re: torque specs for the valvecover bolts. help!! (Natural Aspirated)
14 lb-ft
https://honda-tech.com/zerothread?id=448908
Old Aug 22, 2003 | 02:44 AM
Behan's Avatar
if you search through here they have like three pages of all the torque specs on the car (4th gen). i just printed out a copy and keep it in my tool box/shed.
http://icelord.net/honda/repair/
Old Aug 22, 2003 | 05:24 AM
Daemione's Avatar
Default Re: torque specs for the valvecover bolts. help!! (shakes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shakes &raquo;</TD></TR><TR><TD CLASS="quote">14 lb-ft
https://honda-tech.com/zerothread?id=448908 </TD></TR></TABLE>
That thread is talking about adjusting the valves - he's just tightening the valve cover nuts.
I believe torque specs for those is like 7.8 ft/lbs., something like that - not much at all. If you look at them funny, they will strip - so go really easy on them.
Old Aug 22, 2003 | 06:25 AM
Jagan'92's Avatar
Default Re: torque specs for the valvecover bolts. help!! (Daemione)
http://icelord.net/honda/repai...s.pdf
page 3: correct me but i read 7 INCH pounds. wtf is that? should be 7ft/lb
Old Aug 22, 2003 | 08:30 AM
GruvyTune's Avatar
New User
Default Re: torque specs for the valvecover bolts. help!! (Jagan'92)
it 7.8 ft-lb not inch-lbs! not 14!! you'll strip them at 14. should be just enough to compress the rubber bushing on the seals but not enough to fully tighten them
Old Aug 22, 2003 | 12:21 PM
optikal_blitz's Avatar
Default Re: torque specs for the valvecover bolts. help!! (GruvyTune)
uh oh..id better go out and loosen up my valve cover bolts then..i was told there's no spec on them so i just tightened them down hard.
by the way, there is such thing as inch-pounds..
Old Aug 22, 2003 | 01:02 PM
spoolinlude's Avatar
I live under a rock
Default Re: torque specs for the valvecover bolts. help!! (NatakuBlitz)
yep..... inch pounds exist, I have an inch pound torque wrench believe it or not
Old Aug 22, 2003 | 01:26 PM
GeeReg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NatakuBlitz &raquo;</TD></TR><TR><TD CLASS="quote">there is such thing as inch-pounds..</TD></TR></TABLE>
If you say so....
Old Aug 22, 2003 | 02:40 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jagan'92 &raquo;</TD></TR><TR><TD CLASS="quote">http://icelord.net/honda/repai...s.pdf
WOW what a website
Old Aug 22, 2003 | 03:16 PM
LudeyKrus's Avatar
Default Re: torque specs for the valvecover bolts. help!! (spoolinlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinlude &raquo;</TD></TR><TR><TD CLASS="quote">yep..... inch pounds exist</TD></TR></TABLE>
Yep, last week I snapped a headstud on my VW Beetle b/c I didnt pay attention...84 in/lbs is NOT the same as 84 ft/lbs!!!
Old Aug 22, 2003 | 04:10 PM
TimeRacer's Avatar
Default Re: torque specs for the valvecover bolts. help!! (LudeyKrus)
Just thinking, an inch pound would be a heck of a lot less force (considering the less leverage) comparing it against a ft/lb. Here's a quite search turned up.
http://members.aol.com/pullingtractor/formulas.htm
Old Aug 23, 2003 | 07:47 AM
GeeReg's Avatar
Default Re: torque specs for the valvecover bolts. help!! (TimeRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TimeRacer &raquo;</TD></TR><TR><TD CLASS="quote">Just thinking, an inch pound would be a heck of a lot less force (considering the less leverage) comparing it against a ft/lb.
Yes. 1/12th actually.
jarven093
Apr 23, 2007 11:39 AM
teggyracer91
Apr 3, 2007 06:04 AM
b00st Junkie
Honda Motorcycles
Dec 17, 2006 12:44 PM
drudy
Jan 31, 2005 03:03 PM
h22mark
Aug 16, 2004 02:04 PM
