2 Step Colder Sparks For Turbo?
Old Aug 21, 2003 | 06:34 PM
Vtec92Civic's Avatar
Default 2 Step Colder Sparks For Turbo?
Why is it that you need colder spakrs for turbo setups?
Old Aug 21, 2003 | 06:42 PM
InTeGrA B18b1's Avatar
Default Re: 2 Step Colder Sparks For Turbo? (Vtec92Civic)
bkr7e ngk
Old Aug 21, 2003 | 06:43 PM
Default Re: 2 Step Colder Sparks For Turbo? (InTeGrA B18b1)
so you wont detonate or run outtta spark or something, somebody willl tell u
Old Aug 21, 2003 | 06:57 PM
Nextelbuddy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InTeGrA B18b1 &raquo;</TD></TR><TR><TD CLASS="quote">bkr7e ngk</TD></TR></TABLE>
where can i get these spark plugs at?
Old Aug 21, 2003 | 07:12 PM
TeStUdO's Avatar
Default Re: 2 Step Colder Sparks For Turbo? (nextelbuddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy &raquo;</TD></TR><TR><TD CLASS="quote">
where can i get these spark plugs at?</TD></TR></TABLE>
autozone, napa, pep boys. almost any automotive store
edit: only go 1 step colder, 2 steps is a little much
Old Aug 21, 2003 | 08:46 PM
Poop111444's Avatar
Default Re: 2 Step Colder Sparks For Turbo? (TeStUdO)
Honestly, I have had no luck getting those plugs at my local NAPA, and NAPA has more **** than Autozone or Poop Boys.
I always order BKR7es from SUmmit Racing
Old Aug 21, 2003 | 08:50 PM
TeStUdO's Avatar
Default Re: 2 Step Colder Sparks For Turbo? (si_mekanik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si_mekanik &raquo;</TD></TR><TR><TD CLASS="quote">Honestly, I have had no luck getting those plugs at my local NAPA, and NAPA has more **** than Autozone or Poop Boys.
I always order BKR7es from SUmmit Racing</TD></TR></TABLE>
damn, my napa gets them for me in 2 days. autozone stocks them sometimes. that sucks for you bro
Old Aug 21, 2003 | 08:57 PM
mrod006's Avatar
i get them from advance auto and i get them within a day. autozone and o'reilly's didn't have them.
Old Aug 21, 2003 | 09:11 PM
LiLOtaku's Avatar
Default Re: 2 Step Colder Sparks For Turbo? (mrod006)
Your only gonna need 1 step colder. If your running more than 400hp with high compression, most of the veterans recommend going 2 steps colder.
Old Aug 21, 2003 | 11:57 PM
Ben Huynh's Avatar
NGK can explain better than I can so here you go:
http://www.ngksparkplugs.com/t...ry=US
Old Aug 22, 2003 | 12:19 AM
oscarmayer's Avatar
Default Re: 2 Step Colder Sparks For Turbo? (LiLOtaku)
2 steps colder IS always recommended for turbo application.
1 step colder is for light nitrous applications.
colder spark plug helps reduce heat in the chamber (if i rember correctly) which helps cut down on detination. you also should reduce the gap to like .032"
Old Aug 22, 2003 | 03:47 AM
ladysman's Avatar
Default Re: 2 Step Colder Sparks For Turbo? (oscarmayer)
This should help some:
https://honda-tech.com/zerothread?id=510127
And yes, if you aren't running 400 horse, 2 step colder is to much. Just go 1 step colder.
Old Aug 22, 2003 | 08:24 AM
mrod006's Avatar
Default Re: 2 Step Colder Sparks For Turbo? (ladysman)
if i have 2 step colder plugs, will it cause the car to bog down in the low rpms?
Old Aug 22, 2003 | 09:33 AM
R6Elmo's Avatar
if you run plugs that are too cold, you run the risk of fouling your plugs. This would basically happen when you are in traffic or waiting at a red light. no fun
Old Aug 22, 2003 | 10:12 AM
ELSpool's Avatar
I'm going to try and run one step colder, I seem to get fouled plugs at idle with teh current 2 heat range colder plugs, but I can deal with that, I'm just more concerned with det.
Old Aug 22, 2003 | 10:21 AM
mos's Avatar
mos
Default Re: (ELSpool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool &raquo;</TD></TR><TR><TD CLASS="quote">I seem to get fouled plugs at idle with teh current 2 heat range colder plugs, but I can deal with that, I'm just more concerned with det.</TD></TR></TABLE>
Werd, I'd rather have foulded plugs than blowded up pistones.
Old Aug 22, 2003 | 10:22 AM
VTC_CiViC's Avatar
http://www.clubplug.net (or.com?)
I bought my BKPR7E-11's there, 10 for like $20 shipped!
Old Aug 22, 2003 | 10:42 AM
Default Re: (VTC_CiViC)
i think its like 1.80 at advance auto , well less then 10 dollars delivered next day
Old Aug 22, 2003 | 11:00 AM
st00pid's Avatar
Default Re: (InTeGrA B18b1)
The reason to go with a colder plug is that the plug tip retains a certain amount of heat to clean itself. The heat is much higher when turbocharged. Hotter plugs will retain more heat and can actually start glowing and cause preignition and detonation. I am much more conservative when it comes to plug heat ranges. I run a number 7 NGK to about 300whp or about 10-12psi on pump gas. I run a Number 8 plug to 450-475whp and number 9 past that. I also assume that the cars I tune or build are going to be beaten to death. Meaning a lot of Top end runs to 140+ (very popular in Texas.. I dont know why) and hot laps at the drag strip. When you run a car hard like that A LOT of heat gets built up in the combustion chambers. Thats a lot of heat for the plugs to see (theyre sitting in the middle of it.) So the colder the plug the less likely they are to heat up to the point where they would glow and possibly preignite the air/fuel mix.
At least that what I heard.
Old Aug 22, 2003 | 11:03 AM
mos's Avatar
mos
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">I bought my BKPR7E-11's there, 10 for like $20 shipped!</TD></TR></TABLE>
BKPR7E-11?? They make those special just for you?
Old Aug 22, 2003 | 11:13 AM
ATS*Mark's Avatar
OG triple OG
Default Re: (mos)
i have a durbo d16 ,which plugs should i get???
Old Aug 22, 2003 | 11:14 AM
VTC_CiViC's Avatar
Default Re: (mos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mos &raquo;</TD></TR><TR><TD CLASS="quote">
BKPR7E-11?? They make those special just for you? </TD></TR></TABLE>
BCPR7E-11...
Old Aug 22, 2003 | 11:18 AM
ELSpool's Avatar
Default Re: (TURSpoonEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURSpoonEK &raquo;</TD></TR><TR><TD CLASS="quote">i have a durbo d16 ,which plugs should i get???</TD></TR></TABLE>
ZFR6 for 75-100 hp over stock
ZFR7 for 100-200ish hp over stock
you get the picture.
Old Aug 22, 2003 | 06:10 PM
ATS*Mark's Avatar
OG triple OG
is that ngk brand?
Old Aug 22, 2003 | 06:53 PM
hawjdude's Avatar
you get the picture.</TD></TR></TABLE>
i use ngk zfr7. I get my stuff at bumper to bumper and they always have it in stock.
