Where on my charge pipe should I install my NX Express Nozzle?
Old Aug 21, 2003 | 05:33 PM
BodyKits NW's Avatar
Default Where on my charge pipe should I install my NX Express Nozzle?
I got a Stage 1 kit and was wondering where on my charge pipe I should install it. I was thinking of using 1 of the 2 holes I already have on the charge pipe. I didn't know if that was too close or not. Since I am running a ENDYN catch can setup and have my IAT on the back of the intake manifold I have no use for both the holes on the charge pipe. If I could use 1 of them then great, then all I have to do it plug 1 of them. I was thinking of using the one with the rubber groumet in it. If I remove it there is a hole already there which needs to be slightly enlarged. Then I can just plug the other one which I believe is used for the PCV system.
Let me know your thoughts on this. Thanks!
Old Aug 21, 2003 | 06:07 PM
rOby's Avatar
Default Re: Where on my charge pipe should I install my NX Express Nozzle? (BodyKits NW)
put it 3-6" away from the tb
Old Aug 21, 2003 | 08:27 PM
RH+G's Avatar
Is your charge pipe hitting your frame? Aint that gonna be a problem when driving?
Old Aug 21, 2003 | 08:32 PM
Poop111444's Avatar
Default Re: Where on my charge pipe should I install my NX Express Nozzle? (RH+G)
I would put it right before your silicone connector.
Old Aug 21, 2003 | 08:55 PM
FormulaGSR's Avatar
Default Re: Where on my charge pipe should I install my NX Express Nozzle? (si_mekanik)
measure back 4-6 inches from the throttle PLATE, not the throttle body. Mountit before the bend so there is a straight shot into the manifold. I mounted mine on tthe bottom side of the intake pipe, but do whatever works best for you. Just make sure there arent any obstructions in the path of the nitrous/Fuel mixture.
Old Aug 22, 2003 | 07:54 AM
sporkcrx's Avatar
Default Re: Where on my charge pipe should I install my NX Express Nozzle? (FormulaGSR)
RHD Car looks nice, any more pics?
Old Aug 22, 2003 | 02:01 PM
Default Re: Where on my charge pipe should I install my NX Express Nozzle? (sporkcrx)
I'll post some pics later. The car is pretty messy.
BlackLX4
Sep 18, 2016 06:45 AM
r0yal
Welding / Fabrication
Apr 19, 2006 07:03 PM
FURACERMAN
Jan 6, 2006 06:32 PM
Trigun
Apr 15, 2002 12:16 PM
