B16 Swap Can I leave the Front Mount
Old Aug 21, 2003 | 04:24 PM
freeeked's Avatar
Default B16 Swap Can I leave the Front Mount
I couldn't find the answer in the archives. I understand that when I swap the b16 in using Hasport mounts, I do not need the front mount any longer. Hasport does not mention whether I need to cut the front mount off. Can I leave it?
Old Aug 21, 2003 | 04:41 PM
Fred n J_v2.0's Avatar
cut it off or else the mount will hit against the tranny causing a vibration
-well, at least thats what i did
Modified by 95VXFRANK at 9:02 PM 8/21/2003
Old Aug 21, 2003 | 04:50 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (95VXFRANK)
It probably depends on your car,but I left mine on..
Just in case I wanted to go back stock...
I have a lift so I put the engine in from the bottom
with the cross member removed so it was not in the way.
There is probably 1/4" of clearance and with Hasports
the engine does not move around much.
Old Aug 21, 2003 | 04:51 PM
escocrx's Avatar
Default Re:
i have the front mount on my b16 swap in 91 crx.
total of 4 mounts.
it is custom. all mounts were done way back all custom. all are from some honda jus modified
Old Aug 24, 2003 | 10:41 PM
Nerologic's Avatar
leave the mount off you dont need it i dont have a front mount on my crx, but my hatch dose have the front, but they are the jdm mounts not hasports
axionm1k
Jul 4, 2008 11:17 AM
fastcrx420
Mar 14, 2006 05:52 PM
CRX MASE
May 5, 2005 08:32 PM
SkunkCrxSi
18
Jul 23, 2004 07:34 AM
johnzm
11
Jul 30, 2002 06:15 PM
