pretty pissed about results...
Old Aug 21, 2003 | 11:39 AM
[tk4L] Doke's Avatar
Default pretty pissed about results...
98 b18c
Toda B's
Toda camgears
Toda valvetrain
Portflow Ti. retainers
Mugen headgasket
Hondata IM Gasket
DC JDM 4-1 SS header
AEM intake
Mugen twin-loop catback
Highflow cat
Hondata S100
I think thats it for now, definently plan on getting a new intake/header setup when i get some money. The car was dynoed a few days ago and put down like 168whp . My friends took the car there for me and the tuner said the timing belt was loose, temperature sensor wasnt plugged in on the intake mani, and a few other little things. What do yall think, i was def. expecting some more hp, but im guessing my biggest issue is i need compression! Thanks for input...
Also...lots of thanks to Steve at SGT racing...he put up with a lot of bs from me, awesome tuner and good person
Modified by NAsty coupey at 4:12 PM 8/21/2003
Modified by NAsty coupey at 7:00 PM 8/22/2003
Old Aug 21, 2003 | 03:49 PM
chris@allmotor.net's Avatar
Default Re: pretty pissed about results... (NAsty coupey)
sounds about right...i mean, not being harsh, but you cant expect THAT good of numbers with low compression and stuff unplugged/no headwork with those cams.
Old Aug 21, 2003 | 04:18 PM
Tuney's Avatar
Default Re: pretty pissed about results... (chris@allmotor.net)
its not that bad, you can't exect too much with a stock bottom end. Put a test pipe on there and a skunk2 intake mani (assuming its a c1) and thats definetely more power. It only goes up from here!
Old Aug 21, 2003 | 04:20 PM
JCushing's Avatar
ok a stock b18c makes what, 150 to the wheels with bolt ons? you pretty much have intake header exhaust and cams and your makin 18hp over a b18c with bolt ons. i wouldnt be dissapointed. those cams love comression though man, get it to like 11.5:1 and youll be alot happier
Old Aug 21, 2003 | 09:17 PM
yeer's Avatar
whaaat?? damn matt.......
Old Aug 21, 2003 | 09:21 PM
NSX Bob's Avatar
New User
Default Re: pretty pissed about results... (yeer)
You need more compression, bigger injectors, etc. Ask Steve, he'll tell you that .
Old Aug 21, 2003 | 09:36 PM
xJ.SLOTHx's Avatar
get that setup sorted out because 168whp is extremely low
Old Aug 21, 2003 | 11:16 PM
FLOWZILLA's Avatar
POWER SEEMS ON THE MONET OPEN UP THOSE PORTS BUMP THAT COMP. AND THEN YOU WILL SEE THE TRUE POTENTIAL OF THOSE CAMS
Old Aug 22, 2003 | 12:07 AM
Bodman's Avatar
Default Re: pretty pissed about results... (punkonnos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by punkonnos &raquo;</TD></TR><TR><TD CLASS="quote">POWER SEEMS ON THE MONET OPEN UP THOSE PORTS BUMP THAT COMP. AND THEN YOU WILL SEE THE TRUE POTENTIAL OF THOSE CAMS</TD></TR></TABLE>
caps lock ********
yeah, its really all about the compression there... with those cams especially
Old Aug 22, 2003 | 05:32 AM
Default Re: pretty pissed about results... (slow_a$$_eg)
thanks for the input guys, next summer is def. going to be probably a port/polish, injectors, intake mani and new intake.
Old Aug 22, 2003 | 06:09 AM
haggar's Avatar
hmm, if the timing belt is loose(maybe stretched?) is your cam and ignition timing OK? I didn't notice cam gears there, in your list of stuff, so that maybe could help a couple hp. not a lot, but a little anyway..
Old Aug 22, 2003 | 06:40 AM
Casey's Avatar
Default Re: pretty pissed about results... (haggar)
id run open header next time. ive got a jdm b18c which has a little higher comp than you, sk2 manifold, jdm itr header and hondata, oh yeah, a k&n on some random *** stick. I made 182/131 open header. compression with help obvioulsy, as well as cam gears.
Old Aug 22, 2003 | 08:51 AM
GOLDBERG's Avatar
Default Re: pretty pissed about results... (Casey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote">id run open header next time. ive got a jdm b18c which has a little higher comp than you, sk2 manifold, jdm itr header and hondata, oh yeah, a k&n on some random *** stick. I made 182/131 open header. compression with help obvioulsy, as well as cam gears.</TD></TR></TABLE>
what cams?
Old Aug 22, 2003 | 09:14 AM
DOHC SOLDIER's Avatar
Default Re: pretty pissed about results... (ian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ian &raquo;</TD></TR><TR><TD CLASS="quote">get that setup sorted out because 168whp is extremely low</TD></TR></TABLE>
Easy now ian, hp isn't everything and it is a stock bottom end and hooked up to the exhaust with cats. he takes all that off and i bet his numbers improve greatly, his numbers are pretty much where the should be, he probably isn't even using his cams power capabilities with the low compression.
Old Aug 22, 2003 | 10:22 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAsty coupey &raquo;</TD></TR><TR><TD CLASS="quote">98 b18c
Toda B's
Toda valvetrain
Mugen headgasket
Hondata IM Gasket
AEM intake
Highflow cat
Hondata S100
was that 168 with the sensor unplugged or was everything fixed then it was dyno'd ? cause 168 with a 2 layer mugen gasket, some cam gears and a decent ECU generally yields in the 180-185 range even with stock GSR intake manifold.
Have your tuner check the condition of your motor and also show us some a/f graphs with your dyno and we go from there.
Also, I was never a fan of a JDM DC header but to each his own i guess ... i'd take a jdm ITR 4-1 ... **** I'd take a CTR 4-2-1 before a DC !!!
Greg
Old Aug 22, 2003 | 11:03 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAsty coupey &raquo;</TD></TR><TR><TD CLASS="quote"> the tuner said the timing belt was loose, temperature sensor wasnt plugged in on the intake mani, and a few other little things.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAsty coupey &raquo;</TD></TR><TR><TD CLASS="quote">Also...lots of thanks to Steve at SGT racing...he put up with a lot of bs from me, awesome tuner and good person </TD></TR></TABLE>
So was Steve the one who did the tuning? If not, I'm sure he'd be able to find whatever power was left in that engine. If he was, did he offer any other explanations, suggestions, etc.?
Old Aug 22, 2003 | 11:12 AM
GokuSSJ4's Avatar
Default Re: pretty pissed about results... (Padawan)
went your refering to a b18c is that the gsr - j spec or itr motor ??
on your future mods you should try to bump the CR , Toda cams love high CR and you will see more gains . Also do you have cam gears , since it dont mention on your list . That would help !!
Old Aug 22, 2003 | 11:14 AM
Casey's Avatar
Default Re: pretty pissed about results... (GOLDBERG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG &raquo;</TD></TR><TR><TD CLASS="quote">
what cams?</TD></TR></TABLE>
spec b
Old Aug 22, 2003 | 02:23 PM
SignfcntOthr's Avatar
Default Re: pretty pissed about results... (CHEETAH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEETAH &raquo;</TD></TR><TR><TD CLASS="quote">was that 168 with the sensor unplugged or was everything fixed then it was dyno'd ?</TD></TR></TABLE>
What he said.
Old Aug 22, 2003 | 02:54 PM
Rdriver's Avatar
Default Re: pretty pissed about results... (SignfcntOthr)
How many miles are on the motor? What kind of compression numbers are you getting?
Old Aug 22, 2003 | 03:03 PM
the sensor was unplugged yes and there were some vaccum lines also unplugged...so im sure that had some to do with it. Since i fixed those, the car seems to be running a lot better. I def. do need more compression though, but for now im just happy its running good.
Old Aug 23, 2003 | 06:26 AM
T4eg's Avatar
They are decent #'s for the compression. Once you bump up the compression you should be happy.
ekim952522000
Jul 26, 2005 06:24 PM
dacaveman
May 11, 2004 10:58 AM
Montreal R
Oct 29, 2002 08:21 PM
WayneGro
Oct 26, 2001 04:15 PM
CPR
Jul 2, 2001 10:00 AM
