using hondata tuned for supercharger on turbo setup?
i have the chance to get hondata s200 with boost option that was tuned for jackson supercharger on 95 b18c1. my setup is b18c1 with turbo at 7 psi. if i were to get this hondata can i use it for now even though it was tuned on a dyno for supercharger?
No. The performance characteristics of the two systems are very diferent thus the fuel and timing maps are very diferent. The JRSC tune will probably be too rich for your setup. Particularly at lower RPM. See if you can find a tune for your setup on the Hondata site and then find a tuner to burn a ROM for you. It shouldn't cost much at all.
Mike
Mike
should i still get the setup its like 375 bux for hondata s200 w/boost option and i have to give up my stock p72 ecu. the setup is used but i think its still a good deal
where can i find a base map for hondata? i am only going to be running 7psi and thats it. i know someone that can burn the program onto the chip i just need the program thats all
