What wire harness for H22 Accord
Old Aug 20, 2003 | 11:10 PM
Bowlergi21's Avatar
Default What wire harness for H22 Accord
I just got an OBD1 JDM H22 and was wondering what harness i should use to put it in my 00' Accord. Should i convert the motor to OBDII or convert the harness on the car to OBDI. So should i get an OBDII h22 harness or just use the one i have?? Someone help. Whats the easiest way?
Old Aug 21, 2003 | 04:18 AM
KTeller8's Avatar
Default Re: What wire harness for H22 Accord (Bowlergi21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bowlergi21 &raquo;</TD></TR><TR><TD CLASS="quote">I just got an OBD1 JDM H22 and was wondering what harness i should use to put it in my 00' Accord. Should i convert the motor to OBDII or convert the harness on the car to OBDI. So should i get an OBDII h22 harness or just use the one i have?? Someone help. Whats the easiest way?</TD></TR></TABLE>
You will never use the h22 harness in an accord... plain as that, mos ppl ask which harness to you. well you always use the accord harness, it has the plug that will fit into the main body of the Accord: On that note, id say keep your harness and just extend any wires/sensors that dont reach:
Old Aug 22, 2003 | 04:50 PM
IN VTEC's Avatar
Default Re: What wire harness for H22 Accord (KTeller8)
I would cannabalize some of the wires off of the H22 engine harness if the F22 engine doesn't already have the (2) VTEC wires, IAB, and KS wires, as well as some of the H22 wire sections to extend wires on the F22 harness.
Strip down both harnesses and integrate the wires that need to be added before wire looming it back up. Make sure you note which wires are for what if you end up using wiring extensions that are not the same color as the original.
swapsshonda
Jun 3, 2006 07:10 PM
greenli0n25
May 8, 2003 09:55 AM
greenli0n25
May 7, 2003 02:39 PM
