how to: dC2 rear bumper removal
Old Aug 20, 2003 | 10:18 PM
BIGGIDYBOB's Avatar
Default how to: dC2 rear bumper removal
just wanted to ask if anyone has experience in taking off the rear bumper for a 98 integra. i need to do this tomorrow morning so i can have that bumper sanded down and sprayed. where would i find all the bolts needed to take it off? TIA
-rob
Old Aug 21, 2003 | 06:05 AM
junk yard sol's Avatar
Default Re: how to: dC2 rear bumper removal (BIGGIDYBOB)
one screw above each rear tire, then two bolts under car on bottom of spare tire well, then take out the inside cover of the trunk there is going to be a few 8mm nuts to take off the metal trim under the taillights and there are your last screws holding the bumper on.......
Old Aug 21, 2003 | 07:50 AM
VTECorona's Avatar
Default Re: how to: dC2 rear bumper removal (JDMDC2ITR)
Be careful when you remove and replace it. I broke one of the studs that go into the trunk area just from bumping it pretty lightly.
Old Aug 21, 2003 | 08:14 AM
BIGGIDYBOB's Avatar
Default Re: how to: dC2 rear bumper removal (VTECorona)
thanx for the replys!!
Old Aug 21, 2003 | 08:21 AM
Rtzx9r's Avatar
GDD 1%
5-10 minute job max- simple
Old Aug 21, 2003 | 10:26 AM
IntEGNYC's Avatar
Default Re: how to: dC2 rear bumper removal (Rtzx9r)
not that simple on the first go.
Easier once youve' done it or work with someone that has. Always easier with an extra pair of hands.
Old Aug 21, 2003 | 10:37 AM
SilverDc2's Avatar
Default Re: how to: dC2 rear bumper removal (IntEGNYC)
5-10 minutes....i dont think so. its easy just time consuming
Old Aug 21, 2003 | 10:38 AM
VTECorona's Avatar
Default Re: how to: dC2 rear bumper removal (SilverDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 &raquo;</TD></TR><TR><TD CLASS="quote">5-10 minutes....i dont think so. its easy just time consuming</TD></TR></TABLE>
It can be done in that time if you rush. You will probably end up scratching your paint and\or breaking sh*t
Old Aug 21, 2003 | 12:24 PM
integran1's Avatar
i need to get it realigned i need to do it...sigh race day is saturday no time work school gf BAH
Old Aug 21, 2003 | 02:30 PM
BIGGIDYBOB's Avatar
Default Re: (integran1)
yup... got it off in 5 minutes. some of those push button type rivets were breaking on me tho.
Old Aug 21, 2003 | 06:13 PM
B U N M A N G O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDC2ITR &raquo;</TD></TR><TR><TD CLASS="quote">one screw above each rear tire, then two bolts under car on bottom of spare tire well, then take out the inside cover of the trunk there is going to be a few 8mm nuts to take off the metal trim under the taillights and there are your last screws holding the bumper on....... </TD></TR></TABLE>
dang you coupe owners have it hard... for sedans, it's just one screw in each wheelwell, two push rivet things on the bottom, and about 5 or 6 on the top. No need for a rachet set, just a flathead and a philips screwdriver
Si2See
Dec 1, 2009 06:19 PM
1SiKSoL
Jul 22, 2007 01:06 PM
AlxSiR7
Mar 1, 2005 11:23 AM
91HATCH
Nov 24, 2002 02:11 PM
Vazquez911
Feb 17, 2002 11:08 AM
