ecu reccomendations
Old Aug 20, 2003 | 09:29 PM
bavarianblessed's Avatar
Default ecu reccomendations
I have a couple of questions i'm sure you guys can help me with.I am trying to swap
a 00' f23 into a 93' Accord ex and i need to know which ecu i should use.I've already
got a 94' ex ecu on the way(got it really cheap)and had planned on using it since it is also obd1 and will control the vtec operation of the f23.Will this ecu plug strait up without having to re-pin my harness,just adding the needed wires for vtec activation,or should i send off the
93' ecu to say Hondata or Zdyne to have the
00' fuel and timing tables added to it?One other thing i am curious about are the f23's
engine sensors.Will my 93' engine harness be
compatible with the 00' sensors?If not is it possible to put the 93' sensors on the 00' engine?I am low on cash and need to find a way to make this work,so any advise
you guys give will be much appreciated.
best regards,
Scott
baaw1554
Apr 2, 2014 05:53 PM
OneTyteEK9
Apr 27, 2006 09:13 AM
OUTKAST_R
16
Feb 11, 2004 03:02 PM
