catalytic converter
Old Aug 20, 2003 | 06:42 PM
tegrunner's Avatar
Default catalytic converter
my check engine light is on from my carsound cat
is there anyway of overideing this or should i just keep on pulling the negative.
Old Aug 20, 2003 | 08:35 PM
Tweakmeister's Avatar
Default Re: catalytic converter (tegrunner)
02 simulator
Old Aug 20, 2003 | 08:43 PM
psychotic_z's Avatar
^^^^ What he said. You can buy an O2 simulator for about $100 and they fake a voltage signal to your ECU that keeps the code from throwing. My friend bought one for his Cavalier a while back and it works fine. Someone here probably can shoot a link to find one at.
Old Aug 20, 2003 | 11:41 PM
XtremeCarTuner's Avatar
Default Re: catalytic converter (psychotic_z)
Would that solve my problem also? I'm throwing a P0420 code or "Catalyst system efficiency below threshold" on my random technology cat.
Old Aug 21, 2003 | 06:07 AM
Default Re: catalytic converter (XtremeCarTuner)
yes, and they are only $50 or $20 if you make your own.
the 2nd 02 sensor (the one in the cat) is only checking to make sure there is a different reading from the first one.
Old Aug 22, 2003 | 12:15 AM
Default Re: catalytic converter (Tweakmeister)
does anyone know where I can find an 02 simulator?
Old Aug 22, 2003 | 02:09 AM
b18C1_liLkyLe's Avatar
also..try what i did, take ur car to like a smog check place or some where and have your "ecu reset." it worked for my car..also, i heard just disconnecting the battery for a little while and 'power cycling' works.
Another_Teg_Owner
Dec 15, 2003 11:11 PM
jr_istheman
Aug 2, 2002 03:36 PM
onyx00
Apr 16, 2002 01:00 PM
DelsolVtec18
Sep 6, 2001 01:11 AM
