Going to do a tuneup.. $?
I want to change my plugs, cap and rotor before I take my car on this roadtrip I'm going on. How much does all this usually run? I'm going to have someone stop by acura for me. I can't call and ask so I turn to HT again.
I'm guessing most of HT sticks to OEM parts like this, correct?
that is a easy job to do. Get the oem stuff if you can get a deal on it. The cap and rotor are easy to change all you need is a phillips screwdriver.
the ngk coppers part# is bkr6e-11
The dis.cap & rotor are about $15$20 each depending on where you go. You do not need to change to spark plugs yet but if you insist, the NGK plantinum for the GSR are about $16-$18 a piece.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mickey513 »</TD></TR><TR><TD CLASS="quote">The dis.cap & rotor are about $15$20 each depending on where you go. You do not need to change to spark plugs yet but if you insist, the NGK plantinum for the GSR are about $16-$18 a piece.</TD></TR></TABLE>
You don't need platinum. Most people rather use the regular ones instead.
Change your cap, rotor, wires every 30k.
30k or every two years roughly.
If youre going on a long road trip and considering some performing some maintenance, might be worth changing the fuel filter, transmission oil and motor oil.
I just got around to changing the clutch fluid and didnt realize it was all black... After the job, it felt heaps better.
Overall, your car would appreciate it
SR20 Inside
20
Mar 19, 2007 11:00 PM
BoostinEJ1
15
Aug 9, 2004 07:02 PM
577HondaPrelude
Feb 20, 2004 09:52 AM
