My steering wheel is shaking when i get to a certain speed
Old Aug 20, 2003 | 04:04 PM
Nizzy's Avatar
Default My steering wheel is shaking when i get to a certain speed
I've had the car for a couple of months now, got rims on it and have had it dropped since then. I'm sure that that has something to do with it, but not too sure. I'm really not sure when it started shaking. I checked all the nuts on it and haven't had a flat. It only does it when i get on the highway arould 65 mph. will a rotation help or could it be something else?
Old Aug 20, 2003 | 04:56 PM
civicboisi's Avatar
Default Re: My steering wheel is shaking when i get to a certain speed (Nizzy)
Rebalance wheels...
Wheels might be cheap...or bent
Bad tires....
But go with the rebalancing the wheels first
Check for loose front end parts : Tie Rod Ends, CV Boots, etc...
Old Aug 20, 2003 | 05:03 PM
StimpyBoy's Avatar
Default Re: My steering wheel is shaking when i get to a certain speed (civicboisi)
What he said.
If you rotate your tires, you could possibly rule out tire issues, as long as the shaking is in your steering wheel.
FYI, when I had a shaking steering wheel at higher speeds, it was a combination of loose lower ball joints and tie rod ends. That sucked.
Old Aug 20, 2003 | 07:35 PM
akord 97's Avatar
probably uneven tire wear, rotating the tires will probably solve it.
Old Aug 20, 2003 | 11:20 PM
Slammed89's Avatar
When you buy new rims and lower your car, you should also get an alignment. I went through my first set of tires pretty quick because the toe was out on the front and rear with the new rims. Plus, shaking at around 60 mph usually means your alignment is off. Shaking at 50 or 70 mph usually means your tires are out of balance.
Old Aug 21, 2003 | 07:00 AM
Nick M's Avatar
Default Re: My steering wheel is shaking when i get to a certain speed (Slammed89)
like everyone said, your alignment is probably out of whack and has been since you lowered the car, the bad alignment might have caused you to wear out a suspension component
Old Aug 21, 2003 | 07:31 AM
ddua's Avatar
Balancing IMO
and check for tire wear... dont want to skid on the freeway, do u
apbtwhiskey
21
Sep 16, 2013 05:27 AM
bsmith100
Mar 10, 2010 01:10 PM
SPOOLINmatt
May 29, 2008 11:16 PM
LudeJdm
Sep 28, 2007 04:22 PM
Jer'rome
Aug 12, 2003 08:24 PM
