piston question?
Old Aug 20, 2003 | 01:48 PM
gregsr's Avatar
Default piston question?
will ctr pistons fit on ls rods, and what compression would they yield with a b17 head and a stock three layer head gasket.
also on this motor i'm planning on using my skunk 2 stage 2 cams, will I have piston to valve clearance issues with this setup
Thanks
Greg
Old Aug 20, 2003 | 01:51 PM
Comp97GSR's Avatar
Default Re: piston question? (gregsr)
check here: http://www.c-speedracing.com/h...c.php
Old Aug 20, 2003 | 01:54 PM
Zero4Racing's Avatar
CTR pistons will fit on LS rods and would yield right around 12.1-1 or a little more in the LS block. you do need to have either the pistons machined open around the wristpin or have the rods narrowed to fit. (seen it done both ways, prefer narrowing the rods) with the head not milled (just resurfaced) and the block not decked the piston to valve clearance will be fine to run the skunk 2's.
agp1183
Jan 23, 2006 01:35 PM
mR. Vash
Jul 10, 2004 07:07 AM
volcom40street
Apr 19, 2004 02:28 PM
fox297
Aug 4, 2003 12:39 PM
