97 Accord with OBDI H22 question
Ok I'm sure this has been coverd before but I searched and couldn't come up with anything so I'm asking for your help. I'm preping the car and the motor for the swap currently and I'm wondering what all parts I will need for the conversion to OBDI. Any help is greatly appreciated, thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordhybrid »</TD></TR><TR><TD CLASS="quote">well really to convert to OBD I all you need is a jumper harness for the ECU and the rest is just wiring</TD></TR></TABLE>
yes get you an obd2-1 harness, i can help if you cant find one:
and obd1 ecu
and obd1 ecu
dont forget lots of patience.
things that may be a problem.
you should have the wiring pinouts for the obd1 and obd2 ecus. this is because the jumper harness is designed for a civic or teg and therre may be a few slight changes you have to make.
also make sure you got lots of heat shrink tubing and time to resolder plugs and re wire sensors since locations will be different in some cases.
patience will be your best friend on this wiring...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96-EJ6 B18C »</TD></TR><TR><TD CLASS="quote">Ok I'm sure this has been coverd before but I searched and couldn't come up with anything so I'm asking for your help. I'm preping the car and the motor for the swap currently and I'm wondering what all parts I will need for the conversion to OBDI. Any help is greatly appreciated, thanks.</TD></TR></TABLE>
I have the conversion harness that you need. I am currently having an August sale price on them. check my website or in the Sponsors forum on H-T.
Jason
Jason
jccrews90
Mar 14, 2012 03:57 AM
