feul pump not turning on
the tittle is the main problem what could cause this problem other than a faulty feul pump which was replaced no more than two months ago. i can hear my rely click on and then click off after a few seconds so i dont think it s the relay im not getting any codes and im out of ideas any ideas would help.thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccrx »</TD></TR><TR><TD CLASS="quote">the tittle is the main problem what could cause this problem other than a faulty feul pump which was replaced no more than two months ago. i can hear my rely click on and then click off after a few seconds so i dont think it s the relay im not getting any codes and im out of ideas any ideas would help.thanks
It has to be a faulty fuel pump. If you hear it come on everytime you switch the car on and then you hear it turn off, it can't be a blown fuse, it can't be a wire broken, if it was you would not hear the pump turn on.
It sounds like the pump is bad. Sorry
</TD></TR></TABLE>It has to be a faulty fuel pump. If you hear it come on everytime you switch the car on and then you hear it turn off, it can't be a blown fuse, it can't be a wire broken, if it was you would not hear the pump turn on.
He says his relay clicks but doesn't say he hears the whirring sound frrom the fuel pump.. trust me and replace the relay.. even if thats not the problem it will be soon :-) i've had 3 crx's and 2 needed a new one of those so.. good luck try that first its 50$ from honda
QUiKSR20
Jun 24, 2004 01:28 PM
