JAPANESE INTEGRA SI '94 SPEEDOMETER / WIRING PROBLEMS!
Old Aug 20, 2003 | 05:48 AM
UKCTR's Avatar
Default JAPANESE INTEGRA SI '94 SPEEDOMETER / WIRING PROBLEMS!
HI,
CAN ANYONE HELP, MY FRIEND HAS A '94 INTEGRA SI - 1.8 VTEC. HIS FATHER CHANGED THE CLUTCH FOR HIM, AS HE'S A MECHANIC, BUT ACIDENTALLY SNAPPED THE PLUG THAT GOES FROM THE GEARBOX TO THE SPEEDOMETER OFF. IT HAS DAMAGED THE PLUG, WHICH HE HAS REPLACED WITH ONE OF A 1.5 SOHC VTEC, BUT THE PROBLEM IS THE ORDER THE THREE WIRES GO INTO THE GEARBOX CONNECTOR. THERE IS A BLUE/YELLOW, AN ORANGE AND A BLACK.
DOES ANYBODY KNOW WHAT ORDER THESE GO INTO THE GEARBOX PLUG?
IS THE FACT THAT THE SPEEDOMETER DOESN'T WORK, MAKING THE VTEC NOT WORK AS I BELIEVE THAT VTEC IS SPEED SENSITIVE, HENCE NOT WORKING WHEN YOU REV THE CAR AT A STANDSTILL?!
DOES ANYBODY KNOW WHERE TO PURCHASE THE MANUAL FOR THE '94 INTERGRA SI ONLINE, AS THIS MAY HELP?
THANKS GUYS,
FROM A WORRIED UK OWNER!!
Old Aug 20, 2003 | 08:37 AM
machine4321's Avatar
well i cant help on the wire issue but vtec will not work unles your over 15 kph....but if the vss isnt conected it vtec will not work
ecksman
Nov 26, 2006 06:49 PM
sleepyH22
Sep 28, 2006 06:19 PM
HUYNH
Aug 5, 2006 03:43 PM
carnifex
Mar 3, 2005 06:51 PM
MM's94Civic
Jun 26, 2004 08:27 AM
