what kind of hp have u guys seen with hi compression d16z6 or mini me
Old Aug 20, 2003 | 03:45 AM
racerboyb18c1's Avatar
Default what kind of hp have u guys seen with hi compression d16z6 or mini me
like dynos preferably, thanks
Old Aug 20, 2003 | 03:00 PM
Default Re: what kind of hp have u guys seen with hi compression d16z6 or mini me (racerboyb18c1)
ne body ? i really want to know how much power bisi got on his d15? others would be cool too..
Old Aug 20, 2003 | 03:53 PM
964dgsr's Avatar
id like to know too
Old Aug 20, 2003 | 06:59 PM
stale1 '01 itr 616's Avatar
I know this is kinda off topic but I had 160 to the wheels on my d16 with stock compression and 6psi boost from a jrsc. Almost identicals numbers to a stock type r engine. You could probably check the jackson racing web page for some stock dyno runs on your engine.
Old Aug 21, 2003 | 02:02 PM
Default Re: (stale1 '01 itr 616)
i wanna see built street motors and drag motors , bored stroked u know? crazy compression ratio's.
Old Aug 21, 2003 | 04:31 PM
Unsung's Avatar
Default Re: (racerboyb18c1)
Not too many people do the all motor d-series thing. But just to put it in comparison, The mods it would take you to acheive about 1900-200whp on a B-series, the same relative mods usually net the d-series guys 140-150whp. Also, remember the D is little under 100lbs lighter. D's also tend to make more torque per displacement. Hope this helps some.
Old Aug 21, 2003 | 05:41 PM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
Default Re: (Unsung EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">The mods it would take you to acheive about 1900-200whp on a B-series, the same relative mods usually net the d-series guys 140-150whp. </TD></TR></TABLE>
hmm, haven't seen any dyno graph in that power range floating around at all though. have you seen any?
Old Aug 21, 2003 | 06:01 PM
Unsung's Avatar
Default Re: (GhettoRacer)
I saw a 150whp and I tried searching my *** off, couldn't find it. My numbers might be off a little, but you get the point, their not the best option for all-motor. Boost, that's a differnet story.
Old Aug 21, 2003 | 06:11 PM
matt k's Avatar
i have seen 187hp/171tq with a d16 on the motor
Old Aug 21, 2003 | 08:08 PM
91tegrals's Avatar
thats a lot for a dseries for allmotor were did you see it...
Old Aug 21, 2003 | 08:16 PM
743power's Avatar
Default Re: (91tegrals)
on ef-1.com, rocket said his friend made 137whp on a d15b7 with moderate amount of work.
Old Aug 21, 2003 | 10:57 PM
FLOWZILLA's Avatar
Default Re: (743)
ABOUT 2 YRS AGO WE MADE 130 TO THE WHEELS WITH HEAD WORK ECU AND AN INTAKE BUT KEEPED BLOWING UP BOTTOM ENDS SO SOLD THE HEAD AND SUM ROOKIES GOT A HOLD OF IT AND MILLED IT ABOUT .008 PAST THE INDICATOR AND BLEW UP EVERY TIME THEY RAN IT IT WAS ON A D16Z6
DYNOED AT R&D DYNO
Old Aug 21, 2003 | 11:08 PM
JaeOne3345's Avatar
Default Re: (punkonnos)
builthatch got 164 at the wheels on y8 motor with a1 pistons, headwork and cam.
nathan takuzon got 160 at the wheels. u can see his dyno's on jg's site.
Old Aug 21, 2003 | 11:36 PM
FLOWZILLA's Avatar
Default Re: (743)
THIS MAY BE A LIL OF TRACK BUT HAS ANY 1 HERE BUILT A ZC DOHC WHAT KINDA RESULTS ,HP,COMPLICATIONS,FLOW NUMBERS
IM ASKING CAUSE ITS A SINGLE CAM BOTTOM END AND WITH A GOOD TUNER THERE SHOULD BE A LIL MORE POWER WITH THE TWIN CAM THANX 2 CAM PHASING??
Old Aug 22, 2003 | 12:06 AM
Banned
mugen ZC makes about 200 whp... no where as reliable as B series tho.
Old Aug 22, 2003 | 12:11 PM
RS Machines's Avatar
relaialilty ?? building a engine is building a engine forge is forge stock form is a different storybut a d15 with eagle rods arias pistons a set of gsr bearings arp studs make it as reliable as a built gsr
Old Aug 22, 2003 | 12:32 PM
Doctor CorteZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by punkonnos &raquo;</TD></TR><TR><TD CLASS="quote">ABOUT 2 YRS AGO WE MADE 130 TO THE WHEELS WITH HEAD WORK ECU AND AN INTAKE BUT KEEPED BLOWING UP BOTTOM ENDS SO SOLD THE HEAD AND SUM ROOKIES GOT A HOLD OF IT AND MILLED IT ABOUT .008 PAST THE INDICATOR AND BLEW UP EVERY TIME THEY RAN IT IT WAS ON A D16Z6
DYNOED AT R&D DYNO
could you please turn the CAPS OFF and use some friggen punctuation for christ sake...
Old Aug 22, 2003 | 12:54 PM
Banned
Default Re: (RS Machines)
mainly i was refering to the top end.... to make the hp you have to rev it. B series valve train is better than ZC for sustained hi rpm use. but i agree with you. build it right and D motors certainly are not that bad. but machine work and labor is really the same. if cost is the same between D vs. B, which will you take? B right?
Old Aug 23, 2003 | 04:12 AM
matt k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91tegrals &raquo;</TD></TR><TR><TD CLASS="quote">thats a lot for a dseries for allmotor were did you see it...</TD></TR></TABLE>its a freinds car i help build ill ask him if i can post a dyno graph
Old Aug 23, 2003 | 04:18 AM
matt k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RS Machines &raquo;</TD></TR><TR><TD CLASS="quote">relaialilty ?? building a engine is building a engine forge is forge stock form is a different storybut a d15 with eagle rods arias pistons a set of gsr bearings arp studs make it as reliable as a built gsr</TD></TR></TABLE>yeah until them va boys get there hands on it ill ask dave if its ok to post the dyno of the old motor the single cam guys should like it
Old Aug 23, 2003 | 06:55 AM
hondapwr's Avatar
WHy would anyone waste money on a d15?? A ZC or D16z6 would get you more HP for your money, and wouldn't need the mods.
Old Aug 23, 2003 | 09:59 AM
A D NOH's Avatar
I really don't know
Community Builder
Default Re: (hondapwr)
If you have a CRX HF that is equipped with the clever stripping mod's. A 1.6 liter D series motor will take you a long way.
RS Machines, Your site isnt working, but do you guys offer alot of parts for sohc's? ie, cams, springs, retainers, headwork?
Old Aug 23, 2003 | 11:11 AM
kaimo's Avatar
Hello.
D16Z6 turbo
328hp, only a 14psi boost.
Old Aug 23, 2003 | 11:19 AM
Boostfed's Avatar
New User
Default Re: (dahatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dahatch &raquo;</TD></TR><TR><TD CLASS="quote">i have seen 187hp/171tq with a d16 on the motor </TD></TR></TABLE>
I can vouch was there when it dynoed with my STR TB! Very very impressive, 12.60s in the 1/4 All Motah SOHC.
Old Aug 23, 2003 | 11:35 AM
A D NOH's Avatar
I really don't know
Community Builder
Default Re: (Boostfed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed &raquo;</TD></TR><TR><TD CLASS="quote">
I can vouch was there when it dynoed with my STR TB! Very very impressive, 12.60s in the 1/4 All Motah SOHC. </TD></TR></TABLE>
171ft lbs of tq allmotor sohc with 180+whp ?? ? ?What was it an accord motor??
I doubt it being an allmotor D series making that much tq. Prove me wrong though
