jdm hid ballast wiring hacked up. Help if you can. Plz
Old Aug 19, 2003 | 10:15 PM
ghettocrxsi's Avatar
Default jdm hid ballast wiring hacked up. Help if you can. Plz
Ok I have been searchign for about an hour on jdm hid wiring and have not came to a conclusion. So here goes.
I got a set of used jdm hid ballast from my buddy. They were from a wrecked car. There is only 1 bulb present and its smashed.
So I plan on getting new bulbs and soldering them in. since most new bulbs come with the wiring and not just a bulp.
So my question is do I need to use a relay of anykind with the jdm ballast? Or a fuse inline.
Also There is a white wire and a red wire going to the bulb. Is the red pos and the white negative?
Any help would be appreciated.. Thanks David
Old Aug 20, 2003 | 10:49 AM
Default Re: jdm hid ballast wiring hacked up. Help if you can. Plz (ghettocrxsi)
bump.. help if ya can
Old Aug 20, 2003 | 07:22 PM
ITR#132's Avatar
You dont need a relay. The ballast takes the car voltage and steps it up.
Red is usually pos, but it doesnt matter, a light bulb would work even if you reversed the leads.
Old Aug 20, 2003 | 09:18 PM
Default Re: jdm hid ballast wiring hacked up. Help if you can. Plz (ITR#132)
Thanks alot. I will hook them up in a day or so
choua01
Aug 8, 2010 10:51 PM
OceanStateTuning
Acura TSX
Apr 14, 2007 10:27 AM
DC2Header
Jan 1, 2006 05:03 AM
realis9
Aug 13, 2005 03:48 PM
ghettocrxsi
Aug 22, 2003 12:05 PM
