jdm hid ballast wiring hacked... Help if you can
Old Aug 19, 2003 | 10:14 PM
ghettocrxsi's Avatar
Default jdm hid ballast wiring hacked... Help if you can
Ok I have been searchign for about an hour on jdm hid wiring and have not came to a conclusion. So here goes.
I got a set of used jdm hid ballast from my buddy. They were from a wrecked car. There is only 1 bulb present and its smashed.
So I plan on getting new bulbs and soldering them in. since most new bulbs come with the wiring and not just a bulp.
So my question is do I need to use a relay of anykind with the jdm ballast? Or a fuse inline.
Also There is a white wire and a red wire going to the bulb. Is the red pos and the white negative?
Any help would be appreciated.. Thanks David
Old Aug 19, 2003 | 10:49 PM
uNF$@#!'s Avatar
Default Re: jdm hid ballast wiring hacked... Help if you can (ghettocrxsi)
you cant simply solder it in like that. you will have to cut the smash bulb bases and rewire it yourself, (unless, you want to fry something from water) in which case I would not recommend if you are not an expert at wiring, as your dealing with a lot of juice.
Old Aug 19, 2003 | 10:58 PM
Default Re: jdm hid ballast wiring hacked... Help if you can (Soup ****)
I am pretty good with wiring. I will be soldering the wires and shrinkwrapping. Thanks for your advies. So I can just soldier the new bulbs on.
Old Aug 19, 2003 | 11:03 PM
uNF$@#!'s Avatar
again, i'd advise against it.
I would cut it off first.
Old Aug 19, 2003 | 11:07 PM
Do u advise against cutting off the old bulbs with sockets? That way I can attach new bulbs and sockets onto the ballast by soldering.
Thanks David
Old Aug 20, 2003 | 10:49 AM
Bump. Going to wire them tonight hopefully.
Old Aug 22, 2003 | 12:05 PM
junk yard sol's Avatar
have you read the ballast? it says can kill .. so be careful...
blk_eg4
Jun 20, 2007 12:01 AM
OceanStateTuning
Acura TSX
Apr 14, 2007 10:27 AM
DC2Header
Jan 1, 2006 05:03 AM
trunks028
Aug 3, 2005 02:58 PM
ghettocrxsi
Aug 20, 2003 09:18 PM
