baffled valve cover??? necessary???
Old Aug 19, 2003 | 09:04 PM
b18crx's Avatar
Default baffled valve cover??? necessary???
i understand that the OEM vtec valve covers are "baffled". is this necessary? I am considering the Moroso valve cover due to the accessability of the cam gears without cutting the cover. why wouldnt it also be baffled? its also cut "3/8" of an inch for more hood clearance. does this pose an issue with performance?
thank you for your time and experience.
Old Aug 20, 2003 | 02:15 AM
lazerus's Avatar
Default Re: baffled valve cover??? necessary??? (b18crx)
the baffling in a valvecover is for proper function of the crankcase ventalation system (PCV)
it keeps oil from being directly sucked in from the valve, and instead the vapors get trapped more or less in the baffled area of the valve cover.
Old Aug 20, 2003 | 02:53 AM
97hb's Avatar
Default Re: baffled valve cover??? necessary??? (lazerus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus &raquo;</TD></TR><TR><TD CLASS="quote">the baffling in a valvecover is for proper function of the crankcase ventalation system (PCV)
Yeah, but have you seen how much actually get sucked down your intake
Old Aug 20, 2003 | 04:59 AM
JimBlake's Avatar
Default Re: baffled valve cover??? necessary??? (97hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97hb &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, but have you seen how much actually get sucked down your intake </TD></TR></TABLE>Yeah, but have you seen how much more there would be if the baffles weren't there?
Old Aug 20, 2003 | 06:23 AM
b18crx's Avatar
Default Re: baffled valve cover??? necessary??? (JimBlake)
Why would Moroso even make this valve cover? must be some advantage.....maybe for turbos with catch can
Old Aug 20, 2003 | 06:26 AM
jweller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18crx &raquo;</TD></TR><TR><TD CLASS="quote">Why would Moroso even make this valve cover? </TD></TR></TABLE>
Old Aug 20, 2003 | 06:31 AM
b18crx's Avatar
Default Re: baffled valve cover??? necessary??? (jweller)
just talked with a tech from honda. he says these covers would only benefit if u trailer your car to every event. and for a few runs on the drag strip. guess ill get another.
the moroso cover is nice in that you dont have to cut the tb cover or remove the vc each time you tune or adjust. the tb cover is removeable. great idea if the baffles were in place.
Old Aug 31, 2003 | 09:09 AM
Armaan's Avatar
Just get your stock cover cut by PMP Designs. They did mine, and it came out PERFECT.
When you call, talk to Mondo.
http://www.pmpdesigns.com/On-l....html
Old Sep 5, 2003 | 03:19 AM
mattb16a1civic's Avatar
if you want one i have a moroso for sale, got it off a friend that needed money, now i need money, idk 175 or so. pm me, or just cut yours yourself, mark it out and cut it with a dremel, only if u have a steady hand and a file.
sh!ft
Welding / Fabrication
Aug 12, 2010 01:06 PM
Black R
Jan 25, 2010 07:18 PM
