Ok guys, what YEAR prelude drivers side mount for H22 into 94-97 accord?
Old Aug 19, 2003 | 05:54 PM
KStuned's Avatar
Default Ok guys, what YEAR prelude drivers side mount for H22 into 94-97 accord?
Yes, I SEARCHED... I need to know from what year prelude that the drivers side motor mount needs to come from for an H22 into a 94-97 accord. I am assuming I will need one from the 92-96 prelude,... is this correct? Thanks.
Old Aug 19, 2003 | 07:18 PM
Fastom's Avatar
Default Re: Ok guys, what YEAR prelude drivers side mount for H22 into 94-97 accord? (Hondaddict)
I believe the motor mount near the timing belt on my car is froma 97 prelude VTEC
HASPORT says they have a new one almost ready. Give them a call and see if it is released yet
Old Aug 19, 2003 | 07:46 PM
v4lu3s's Avatar
RTFM
Default Re: Ok guys, what YEAR prelude drivers side mount for H22 into 94-97 accord? (Fastom)
yes the 92-96 will work though you must shave it some i am told.
Old Aug 19, 2003 | 08:27 PM
94AccordCoupe's Avatar
Default Re: Ok guys, what YEAR prelude drivers side mount for H22 into 94-97 accord? (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">yes the 92-96 will work though you must shave it some i am told.</TD></TR></TABLE>
This is true
Old Aug 19, 2003 | 10:14 PM
booja's Avatar
use a 92-96... doesn't matter if it was a h23 or h22..
you gotta shave it down some
Old Aug 20, 2003 | 04:34 AM
iakona's Avatar
use the 1992-1996, BUT you will have to modify it. the mount sits the engine in an awkward spot (a few cms off where it should be) so you have to trim one side of the mount and shim the other (with the proper equipment) to have everything on the level and balanced in the engine bay. good luck! it's a PITA...
Laskowski
Mar 11, 2011 03:10 PM
T9U4ReBgO
Sep 8, 2010 06:49 PM
fastlane2
Sep 13, 2009 09:43 AM
OutlawCL
Oct 2, 2004 11:32 PM
jbonehead85
Sep 28, 2004 06:24 PM
