Torque loss in knife-edging?
Old Aug 19, 2003 | 04:20 PM
LSVTECoupe's Avatar
Default Torque loss in knife-edging?
Is there a considerable amount of torque loss in knife-edging?
Old Aug 20, 2003 | 12:07 AM
LSVTECoupe's Avatar
ttt
Old Aug 20, 2003 | 12:23 AM
The Brown Kid's Avatar
Default Re: (LSVTECoupe)
How come torque is lost in knife edging? the weights momentum provides torque?
Old Aug 20, 2003 | 02:06 AM
lazerus's Avatar
Default Re: (The Brown Kid)
knife edging a crank shouldn't decrease torque. you are lightening rotational mass, the car should revv quicker, and have less fluid friction against the air at high rpms.
Old Aug 20, 2003 | 02:15 AM
eg_type_r93's Avatar
Default Re: (lazerus)
yes you will lose tourque because of the "rotalional mass" just think is you get an ultra light weight flywheel do you not loose tourque
gotta go to a shop with experience they will know the ammount that can be shaved and you will see maximum performance
ie equal balance of tourque and quicker revs
Old Aug 20, 2003 | 05:33 AM
Daemione's Avatar
Default Re: (eg_type_r93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_type_r93 &raquo;</TD></TR><TR><TD CLASS="quote">yes you will lose tourque because of the "rotalional mass" just think is you get an ultra light weight flywheel do you not loose tourque</TD></TR></TABLE>
You lose inertia, not torque.
Knife-edging a Honda crank is pointless since the crank doesn't actually spin through the oil bath. Lightening would show benefits similiar to a lighter flywheel or wheels, though.
Old Aug 20, 2003 | 07:10 AM
altoid's Avatar
Default Re: (Daemione)
remember people torque is the force exerted at a distance beyond the axis of rotation (the crank). No torque is produced directly at the crank its all produced by the angle of the rods and the distance they travel as they descend on the power stroke. so you entire assembly could weigh 2 pounds and assuming it could hold up if its built the same as your motor the only difference will be the amount of energy needed to start & keep it in motion. hope this helps some
http://physics.bu.edu/py105/notes/Torque.html
Old Aug 20, 2003 | 08:25 AM
machine4321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione &raquo;</TD></TR><TR><TD CLASS="quote">
Knife-edging a Honda crank is pointless since the crank doesn't actually spin through the oil bath. Lightening would show benefits similiar to a lighter flywheel or wheels, though.</TD></TR></TABLE>
thank you for getting that right
sea plant
Jun 8, 2008 07:12 AM
Mar 1, 2008 06:43 AM
cleanEG
Jun 12, 2003 04:08 PM
dropt
Mar 28, 2003 11:25 AM
