Anyone running Honda HX wheels.....
Conference rules will only allow a 14x6 for the CRX in FP. I picked up a set of HX wheels..
They're 14x5.5 with a 50mm offset. Only 11.75 lbs each. Wondering if anyone has run these and what size spacer u might have used. I'm thinkin' 15mm would do it.
Ideas??? Thanks
Ideas??? Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattjohnston »</TD></TR><TR><TD CLASS="quote">I run them on my rally car. I attacked my calipers with a grinder.</TD></TR></TABLE>
No spacers?
No spacers?
FP needs real Slicks to be competitive at all.
From my EP Autocross car experience...(I run 13s all around)
A 20x9.5x14 (avaliable?) on a 5 inch backspace will need a 1/4 inch spacer to clear the hub upright.
Well, the part of the steering knuckle that goes to the ball joint to the upper arm.
A 20x8 will fit, no rub.
But,
In the rear, a 20x8 won't fit with a 5 inch backspace. (the 20x9.5 section width is even wider)
A 1/4 spacer won't totally eliminate the rub, but reduce it.
The solution? A 4 1/2 inch backspace.
Stock Honda wheels are 5 inch back space.
Need further explaination?
PM me.
But,
PM me.
DSMAddicted
Sep 2, 2011 10:40 PM
