aiming JDM EG headlight
Old Aug 19, 2003 | 01:15 PM
aira
Guest
Posts: n/a
Default aiming JDM EG headlight
How do you go about aiming this headlight? I recently installed a pair and the aiming is wayy off. It shoots too high and it blinds the people in front of me like i were highbeaming them. I know the USDM headlight has some screws behind it where if you were to unscrew/screw them, they would adjust. I couldn't find these behind the JDM headlight. Any help would be great.
Old Aug 19, 2003 | 01:24 PM
KOALA YUMMIES's Avatar
Default Re: aiming JDM EG headlight (aira)
Go out on an empty street, block one headlight with a towel and adjust the other one with a phillips screwdriver. Just make sure you dont blind anyone.
Old Aug 19, 2003 | 01:29 PM
aira
Guest
Posts: n/a
Default Re: aiming JDM EG headlight (KOALA YUMMIES)
Where's the screw to adjust it? I saw some circular things, but I'm not sure if that's it?
Old Aug 19, 2003 | 01:40 PM
There are two that you adjust. You'll need to point the screwdriver down. One adjusts vertical and one horizontal. They look like little teeth where you put the screwdriver in.
Old Aug 19, 2003 | 04:26 PM
aira
Guest
Posts: n/a
Oh hahaha! I seen those. I never knew how you were supposed to turn those. Thanks I got it now!!!
Old Aug 19, 2003 | 04:27 PM
LHC's Avatar
LHC
i allways wanted to know that as well
dblock2x
Jun 13, 2007 07:57 AM
confusion
May 13, 2007 12:08 PM
harley06
Dec 23, 2006 11:31 AM
Hybrid 350GT
Aug 5, 2004 07:23 AM
