ALERT: I found a way to get the gs-r lca bushings out
Old Aug 19, 2003 | 11:16 AM
Tweakmeister's Avatar
Default ALERT: I found a way to get the gs-r lca bushings out
*[Danger Will Robinson!]*
Old Aug 19, 2003 | 11:19 AM
thaiphob's Avatar
Nikon!!!
Default Re: ALERT: I found a way to get the gs-r lca bushings out (Tweakmeister)
who needs to use a press...when you got FIRE!!!
Old Aug 19, 2003 | 11:33 AM
Default Re: ALERT: I found a way to get the gs-r lca bushings out (thaiphob)
hell yes!
seriously, a press just isn't as satisfying.
Old Aug 19, 2003 | 11:44 AM
Cone's Avatar
even fire didn't work for my friends LCA's on his '93 Civic LX. He had to buy an Integra LCA on the drivers side cuz everything was seized. I gave him my passanger side since I upgraded to SRR LCA's and now he can have a rear sway...
-Andrew
Old Aug 19, 2003 | 01:34 PM
obd2gsr's Avatar
wow! ahahaha
Old Aug 19, 2003 | 02:00 PM
tegasaurus's Avatar
Default Re: ALERT: I found a way to get the gs-r lca bushings out (obd2gsr)
welcome to me 2 weeks ago... i just heated the babies up, watched the rubber drip out likehot candle wax. then i bashed the rings out on the inside.
Old Aug 19, 2003 | 02:41 PM
ragejed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">*[Danger Will Robinson!]*
Thanks for stealing my idea
I posted this a while ago on the fire for the we-tods
Old Aug 19, 2003 | 02:44 PM
ragejed's Avatar
Default Re: ALERT: I found a way to get the gs-r lca bushings out (ragejed)
Theres mine. I did ALL of my bushings that way
Old Aug 19, 2003 | 02:52 PM
greebler's Avatar
Why didn't I think of that!
Very helpful. That makes the Energy Suspension bushing kits look more tempting.
Old Aug 21, 2003 | 07:26 AM
model x's Avatar
Default Re: ALERT: I found a way to get the gs-r lca bushings out (greebler)
Are you guys just using propane?
Old Aug 21, 2003 | 07:35 AM
lustedp's Avatar
Default Re: ALERT: I found a way to get the gs-r lca bushings out (model x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by model x &raquo;</TD></TR><TR><TD CLASS="quote">Are you guys just using propane?</TD></TR></TABLE>
Can't you read? MAPP Gas much hotter
Old Aug 21, 2003 | 08:37 AM
ragejed's Avatar
Default Re: ALERT: I found a way to get the gs-r lca bushings out (lustedp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lustedp &raquo;</TD></TR><TR><TD CLASS="quote">
Can't you read? MAPP Gas much hotter </TD></TR></TABLE>
Actually. Its only 30% hotter. And I did you MAPP. Untill I read on my torch it says PROPANE ONLY. So I went back to propane. It does the job just as well.
Old Aug 21, 2003 | 08:40 AM
Rpc07's Avatar
Default Re: ALERT: I found a way to get the gs-r lca bushings out (tegasaurus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">welcome to me 2 weeks ago... i just heated the babies up, watched the rubber drip out likehot candle wax. then i bashed the rings out on the inside. </TD></TR></TABLE>
yeah i remember that suspension install... its was a nightmare
Old Aug 21, 2003 | 11:00 AM
dom93hatch's Avatar
Default Re: ALERT: I found a way to get the gs-r lca bushings out (Rpc07)
hardcore!
Old Aug 21, 2003 | 01:40 PM
Default Re: ALERT: I found a way to get the gs-r lca bushings out (dom93hatch)
yeah I used Propane.
For my install I went ahead and just bought ITR lca's and shocks that work with ITR's (Koni Yellow for ITR).
that way I could have fun with things like this
Old Aug 21, 2003 | 01:45 PM
TeamSTEALTH GSR's Avatar
fire worked for me..
but DAMN!!! that **** ******* stinks ....
fire+knife=bushing coming off easy
Old Aug 21, 2003 | 01:59 PM
Muckman's Avatar
Moderator in Chief
Haha I did the same thing when I put my new shocks in. I heated mine up so much it caught fire accidently
Then the metal cylindar would clank around in the LCA bushing until I replaced the bushing heh. Fire Ownz
Modified by Muckman at 6:37 PM 8/21/2003
Old Aug 21, 2003 | 02:28 PM
maxxdout's Avatar
Default Re: ALERT: I found a way to get the gs-r lca bushings out (Muckman)
hey peep this: just a thought but, did anyone consider the heat of the fire actually changing or effecting the properties of the metal in the LCA? Possibly weakening the material just enough so that you dont notice it until the control arm is put under heavy load and quite possibly break??
With safety being our first priority lets take this issue into consideration before anyone else goes and attempts this method.
Is it easier, im sure. But, if there are safety implications im sure we would want to know about it and not place any members at risk.
Keep it safe
Old Aug 21, 2003 | 04:34 PM
stumpyf4's Avatar
Default Re: ALERT: I found a way to get the gs-r lca bushings out (maxxdout)
The control arms are just cast iron, they undergo no heat-treating so there aren't any strength properties from heat treating to be lost. As long as the metal doesn't physically melt you're fine. Go ahead and burn away!!
Edit: slap a coat of rustolem on those badies!!
Old Aug 21, 2003 | 04:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxxdout &raquo;</TD></TR><TR><TD CLASS="quote">hey peep this: just a thought but, did anyone consider the heat of the fire actually changing or effecting the properties of the metal in the LCA? Possibly weakening the material just enough so that you dont notice it until the control arm is put under heavy load and quite possibly break??
Keep it safe </TD></TR></TABLE>
Valid argument, but cast iron is fine.
Old Aug 21, 2003 | 04:46 PM
haggar's Avatar
My friend and I were using the same trick to burn out bushings from some leaf springs for a Jeep(I used ot build Harecore offroad Jeeps, then dune buggies, now hondas...go figure..)... he was using an Oxy-acetylene torch.. well the bushing melted into liquid, and POP it exploded, and shot melted rubber all over his face. He was OK, but had these black blast-marks all over his face.. I got a picture somewhere.. looked like a road runner cartoon when someone gets blasted with a canon or something, all blackened..
So, face protection, people!!
Old Aug 22, 2003 | 08:49 AM
Cone's Avatar
Default Re: ALERT: I found a way to get the gs-r lca bushings out (haggar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haggar &raquo;</TD></TR><TR><TD CLASS="quote">My friend and I were using the same trick to burn out bushings from some leaf springs for a Jeep(I used ot build Harecore offroad Jeeps, then dune buggies, now hondas...go figure..)... he was using an Oxy-acetylene torch.. well the bushing melted into liquid, and POP it exploded, and shot melted rubber all over his face. He was OK, but had these black blast-marks all over his face.. I got a picture somewhere.. looked like a road runner cartoon when someone gets blasted with a canon or something, all blackened..
So, face protection, people!!</TD></TR></TABLE>
wow, good thing he was ok, but damn, that might have made a good own3d picture...
-Andrew
Old Aug 22, 2003 | 12:05 PM
Allstar's Avatar
New User
Looks like you had to cut the bottom of your shock off because of the wheel speed sensor line. Same thing happened to me, it sucked.
Old Aug 22, 2003 | 12:21 PM
ragejed's Avatar
Default Re: ALERT: I found a way to get the gs-r lca bushings out (Allstar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Allstar &raquo;</TD></TR><TR><TD CLASS="quote">Looks like you had to cut the bottom of your shock off because of the wheel speed sensor line. Same thing happened to me, it sucked.
Wheel speed sensor, as in ABS line? Just checkin
Old Aug 22, 2003 | 02:17 PM
integerkgsr's Avatar
Ooooooooh i've got you beat!!
blowtorch:
powersaw:
success!!
but wait... it still wont come out. what do u do?
use air hammer!!
but wait... what about the bushing?
you cut the head of a bolt off. weld it in there. and then air hammer that sucker out too and the outer ring of the bushing comes w/ it. WOOO! I got you all owned w/ this one. haha
