what do you guys do when the Rear control arm bolt is frozen or broken?
Old Aug 19, 2003 | 09:15 AM
Integra_Boi's Avatar
New User
Default what do you guys do when the Rear control arm bolt is frozen or broken?
i was lowering a accord today and the rear shocks didn't cooperate.. and my friend went ahead and grabbed a breaker bar and broke the head.. whats my solution to this and how would i get the other side out without doing the same? Thanks
Old Aug 19, 2003 | 09:19 AM
dip-set's Avatar
Default Re: what do you guys do when the Rear control arm bolt is frozen or broken? (Integra_Boi)
take it to a shop to avoid the headaches and frustration
Old Aug 19, 2003 | 11:24 AM
thaiphob's Avatar
Nikon!!!
you could try drilling the broken blot out... if you got air tools handy.
Old Aug 19, 2003 | 01:00 PM
New User
Default Re: what do you guys do when the Rear control arm bolt is frozen or broken? (thaiphob)
i do plan on taking it to the shop because once it happened, i put the wheel back on and said forget it.. hahah.. i knew it was going to happen.. but whats the best method for a shop to do it?.. so they dont charge a arm and leg saying i need to replace the whole thing or whatever...
Old Aug 19, 2003 | 07:27 PM
stumpyf4's Avatar
They'll cut the remainder of the bolt between the shock fork and control arm bushing or cut the shock fork to get the shock/spring assembly out. The old bushing is usually pressed out and a new one pressed in. Guys familar with Hondas can do this while the control arm is still on the car.
Old Aug 19, 2003 | 08:00 PM
1.8tegura's Avatar
buy rear lower control arms...try hybridgarage.com
Old Aug 20, 2003 | 05:12 AM
PnX-R's Avatar
Default Re: what do you guys do when the Rear control arm bolt is frozen or broken? (stumpyf4)
That's exactly what I did.. But I didn't press mine out.. I took a sharp bit and air hammered it out.. Then I pressed a new bushing in with a Universal Ball Joint Press. Pretty easy..
Have fun..
Old Aug 20, 2003 | 07:05 AM
skygtr01's Avatar
Default Re: what do you guys do when the Rear control arm bolt is frozen or broken? (PnX-R)
True dat. I ran into the same problem in the rear of my Integra with the bolt in the sleeved bushing. Couldn't get it out if it killed me. Tried some anti seize and it didn't do anything. I finally took it up to the shop and he said he couldn't torch it because the ABS line runs right through there and it would be expensive to replace that line if it was ruined. So he ordered just that part what ever the bushing thing is called and cut it out and replaced it with the new part. But he said another alternative was to replace the whole lower rear control arm which would only have been $98 each side for my GS-R.
f15Civic
33
Nov 7, 2015 01:58 PM
Tong.Y
Jun 14, 2010 12:33 AM
MaXiMuS1701
Jun 29, 2007 10:12 PM
BG-Teg
Jun 3, 2007 06:54 PM
inTeGra_LivesOn
Jan 22, 2005 12:17 PM
