Oil Breather to replace the vaccumhose leading into intake
Old Aug 13, 2001 | 12:58 PM
Toda Party's Avatar
Default Oil Breather to replace the vaccumhose leading into intake
Where did you buy urs? I found a site that sold them but i CAN'T find it and im getting pissed off!
Old Aug 13, 2001 | 01:05 PM
sackdz's Avatar
Default Re: Oil Breather to replace the vaccumhose leading into intake (NBP ITR 01-622)
= bad for your motor
Old Aug 13, 2001 | 01:14 PM
98TypeR's Avatar
Default Re: Oil Breather to replace the vaccumhose leading into intake (sackdz)
just go to any aftermarket parts shop. they should have them for like 15 dollars. Its not good for your engine though.
Old Aug 13, 2001 | 01:15 PM
Toda Party's Avatar
Really? How is it bad? (im not arguing, just curious)...I was under the impression it was better since it doesnt cycle oil thru ur intake and clog ur t/b...
Old Aug 13, 2001 | 01:32 PM
Black Dragon
Guest
Posts: n/a
Default Re: Oil Breather to replace the vaccumhose leading into intake (98TypeR)
Yea, I wanna know too, why is it bad?
Oil does not get into your intake with the hose. If it is, you are doing something wrong. The flow goes IN not OUT, NO oil should come out of that hose or oil breather.
The only thing possibly different with the oil breather is PERHAPS there isn`t such a strong flow of air.
Old Aug 13, 2001 | 02:01 PM
brinks's Avatar
Default Re: Oil Breather to replace the vaccumhose leading into intake (Black Dragon)
Wrong, check your shop manual, the airflow diagram FROM HONDA shows positive flow from the intake into the crankcase, not from the crankcase to the intake. By installing the breather you are doing nothing but interrupting this flow, only necessary if you have a pressurized intake system, i.e. a turbocharger.
A good question is, if someone is going to run N2O, should they install a breather to prevent nitrous from entering the crankcase through that hose?
Old Aug 13, 2001 | 02:17 PM
JohnnyBoy's Avatar
Default Re: Oil Breather to replace the vaccumhose leading into intake (brinks)
Just run a ctach can.
Old Aug 13, 2001 | 02:20 PM
sgT's Avatar
sgT
There's no way anything other than boost is going to overcome the flow of air
coming out of my valve cover. As a matter of fact, my crankcase pressure is so
high i'm probably going to have to install vents. Then maybe something might
be able to push its way into the valve cover.
Even so, the stock tube going into the intake hose isnt shaped in a way that
promotes any sort of flow TOWARD the valve cover. I know on older hondas
they were, but all the newer ones I have seen are not.
Old Aug 13, 2001 | 02:28 PM
JDM R98's Avatar
Default Re: Oil Breather to replace the vaccumhose leading into intake (sgT)
by using a breather is it bad for your car?
Old Aug 13, 2001 | 02:41 PM
Black Dragon
Guest
Posts: n/a
That`s what I`m saying.
BUT, why does installing the breather interrupt this flow? AND, why do some say the breather is bad for the engine?
If the crankcase needs O2 then it takes O2, whether it is from the hose connected to the intake or through the little breather.
I "installed" an oil breather when I put on my AEM and if this is bad then I want to know so I can take it off.
Old Aug 13, 2001 | 03:48 PM
Toda Party's Avatar
Yeah, i installed my intake and I saw another R with the little breather and that's why I was asking...
Old Aug 13, 2001 | 06:18 PM
Double 06's Avatar
New User
I never had a problem, here's a pic.
[Modified by Double 06, 7:18 PM 8/13/2001]
Old Aug 13, 2001 | 06:46 PM
EPGONZALEZ's Avatar
Default Re: Oil Breather to replace the vaccumhose leading into intake (Double 06)
was talking to a guy from BENIN this weekend..he had some crazy insight on the pcv system for hondas..ill keep you posted..if what he said works, alot of us auto-xers and road racers are gonna be real happy
Old Aug 14, 2001 | 04:44 AM
DutchITR1689's Avatar
There is another hose coming out of the crankcase (not valve cover) that goes to a black box (filter/oil catch can?) and then to the intake manifold. I think that is the crankcase ventilation (pcv). The hose from the intake to the valve cover is for letting air in the engine.
Old Aug 14, 2001 | 05:22 AM
ZygSpeed's Avatar
Default Re: Oil Breather to replace the vaccumhose leading into intake (EPGONZALEZ)
Thanks EPG, always nice to be aware of the little tech tip and tricks.
Old Aug 14, 2001 | 08:40 AM
BSQ's Avatar
BSQ
Default Re: Oil Breather to replace the vaccumhose leading into intake (EuroITR1689)
This is true. Here is a diagram from T.O.O ( http://www.theoldone.com ) which shows how a oil catch can should be installed on a Honda/Acura.
Old Aug 14, 2001 | 08:47 AM
Default Re: Oil Breather to replace the vaccumhose leading into intake (BSQ)
So, this is not the hose that is connected to the valve cover and intake hose. But why do some people connect the hose at the valve cover to an oil catch can? And if the the valve cover hose is sucking air why bother putting a small breather filter on it instead of leaving it stock?
Old Aug 14, 2001 | 09:29 AM
BSQ's Avatar
BSQ
Correct. Probably because they are misinformed.
Exactly.
Old Aug 14, 2001 | 09:35 AM
This is a picture from http://www.theoldone.com to confirm this.
Old Aug 14, 2001 | 10:35 AM
MintyDip's Avatar
I been using a little breather filter for a while. Maybe a year. I never had a probelm, but if it is bad, I will use a tube and connect it back to the intake. never knew it was bad. Maybe I will get a catch can.
there was one time, when oil was coming out of the breather filter.....that was my only problem. It happened after an oil change. So maybe the oil did go down yet.
Is it bad to not use the metal pcv valve for the intake hose and coolant? I rerouted my coolant to just a tube. bad?
Old Aug 14, 2001 | 10:40 AM
BSQ's Avatar
BSQ
Yes, this is the same setup I have on my car. You can go to my website at http://www.geocities.com/bretq/DIY_O...tructions.html for further information and instructions on how to make this oil catch can.
Here is a picture of my oil catch can:
Old Aug 14, 2001 | 02:53 PM
JohnnyBoy's Avatar
Double 06 - what kind is that..that looks cool.
Old Aug 14, 2001 | 03:50 PM
Double 06's Avatar
New User
Default Re: Oil Breather to replace the vaccumhose leading into intake (JohnnyBoy)
jaz catch can
Old Aug 14, 2001 | 05:43 PM
JohnnyBoy's Avatar
Where can you get them?? Thanks
Old Aug 14, 2001 | 07:19 PM
VTEC Girl's Avatar
New User
If anyone is still confused on who is right... go grab a new PCV and try sucking/blowing on the end where your hose would be clamped on and see which way air flows.
