question about itr strut bar installation
Old Aug 19, 2003 | 05:11 AM
dip-set's Avatar
Default question about itr strut bar installation
ok ive had the bar on for quite some time but yesterday i went to check the nuts and bolts that hold it on and noticed one was stripped..i think when i had my suspension done 2 weeks ago the shop overtighted it and stripped the threads...
my question(s)..
when u put the bolt up through the wheel well is there supposed to be a washer on the bolt to keep the bolt from going/tearing through the wheel well area...and should a washer be put on before u tighten the nut down or just tighten the nut down on the bar...i want to know the best way to have it on...thanks
Old Aug 19, 2003 | 06:03 PM
CWITR's Avatar
Default Re: question about itr strut bar installation (teg-your-it)
You should not have to put a bolt up through the engine bay because it should be welded to the car. My ITR does not have any washers to hold the bar down. The nuts should have a flange toward the bottom to keep the bar down tight. Just tighten the nut down on the bar.
Old Aug 19, 2003 | 06:10 PM
timmy8151's Avatar
Default Re: question about itr strut bar installation (CWITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CWITR &raquo;</TD></TR><TR><TD CLASS="quote">You should not have to put a bolt up through the engine bay because it should be welded to the car. My ITR does not have any washers to hold the bar down. The nuts should have a flange toward the bottom to keep the bar down tight. Just tighten the nut down on the bar.</TD></TR></TABLE>
Non-vtec integra's don't come with an OEM strut bar, so there aren't any bolts, but instead plastic covers. When I put on a strut bar, I used a washer on the fender side.
Old Aug 20, 2003 | 09:52 AM
dip-set's Avatar
Default Re: question about itr strut bar installation (timmy8151)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">
Non-vtec integra's don't come with an OEM strut bar, so there aren't any bolts, but instead plastic covers. When I put on a strut bar, I used a washer on the fender side.</TD></TR></TABLE>
im guessing the biggest washer u could fit on the bolt with out it sliding off the other end right...
Old Aug 20, 2003 | 10:40 AM
96IntegraLS4DR's Avatar
Just take off one bolt, go to Home Depot and ask for fender washers. Those have pretty big outside diameter.
On the side note, I use lock nuts on the strut bar to prevent things from vibating apart.
Old Aug 20, 2003 | 10:33 PM
STDClayton's Avatar
Default Re: question about itr strut bar installation (96IntegraLS4DR)
ha, i work at home depot, and we've got **** loads of different sized outer diameter fender washers, and lock washers aren't a bad idea either. that way you get it tight enought to not come loose, but not too tight. **** hot.
tylertocker
Sep 13, 2007 08:29 AM
LaosGuySi
Apr 25, 2007 11:03 PM
duneracer69
Feb 6, 2006 11:38 AM
redacura
Mar 3, 2004 06:27 PM
bonta-kun
Apr 24, 2003 10:48 PM
