timing belt?
Old Aug 19, 2003 | 04:04 AM
GDM Z28's Avatar
Default timing belt?
will a GSR timing belt fit on my LS motor? someone has a brand new one local for cheap and i have to find out cause i need one. please let me know. thanx
Old Aug 19, 2003 | 04:26 AM
monicle's Avatar
Default Re: timing belt? (civicflnum1)
I havent actually tried it out I do however know that the waterpump gears arent the same and have different ammount of teeth on them. by that comparrison alone Im going to go with "will not work"
Old Aug 19, 2003 | 04:28 AM
GDM Z28's Avatar
Default Re: timing belt? (monicle)
thats weird cause everyone else said the GSR water pump works on the LS motor. so if the water pump works i figured the timing belt would work....any one else have $.02 i can borrow?
Old Aug 19, 2003 | 06:38 AM
hatchdrvr's Avatar
a GSR water pump and oil pump will work on an LS block, but the number of teeth the gears are different so the GSR timing belt will on work on an LS block if you are running the GSR water pump and oil pump.
Old Aug 19, 2003 | 09:44 AM
GDM Z28's Avatar
Default Re: timing belt? (hatchdrvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchdrvr &raquo;</TD></TR><TR><TD CLASS="quote">a GSR water pump and oil pump will work on an LS block, but the number of teeth the gears are different so the if you are running the GSR water pump and oil pump.</TD></TR></TABLE>
can u say that again?
Old Aug 19, 2003 | 09:47 AM
keithv's Avatar
a GSR pump will bolt onto a LS block. the GSR pump is not the same as the LS pump, though. the GSR pump has a different number of teeth on it than the LS does.
does that make sense?
Old Aug 19, 2003 | 10:01 AM
GDM Z28's Avatar
Default Re: timing belt? (keithv)
yeah i know the pump will work with my motor but what about the gsr timing belt....i need a simple answer yes or no...... thanx
Old Aug 19, 2003 | 10:03 AM
keithv's Avatar
no.
Old Aug 19, 2003 | 10:25 AM
GDM Z28's Avatar
ok thanx. so if i use the water pump...the ls timing belt will still work with that water pump right?
Old Aug 19, 2003 | 10:31 AM
keithv's Avatar
LS water pump + LS motor = LS timing belt
its pretty simple.
Old Aug 19, 2003 | 10:32 AM
GDM Z28's Avatar
yeah it is but i cant get a brand new LS water pump for 30 bucks or less and id do that instead of paying what ever the ls one is.
JTTeG_X
Jul 17, 2013 10:50 AM
grant97teg
Apr 27, 2009 10:44 AM
natecivic92
Feb 23, 2008 09:13 PM
shortyz21
Nov 12, 2006 08:38 AM
tegasaurus
Aug 10, 2003 01:07 PM
