Haw far can a non vtec B20 Bor Z be taken
Is it possible of reaching 200whp.
even with cams pistons etc etc etc
I really like the torque, thats why Im asking.
Let m eknow as much as possible
Thanx
Thanx
https://honda-tech.com/zerothread?id=520581
freaken use the search button.
If you did use search and try your hardest to find info...I worry for you bro
yes 200whp on a NA Dohc non-vtec (B20/LS) is possible with lots of money. You'll need whats talked about in that thread plus:
crazy high compression ratio....+14.1:5
race gas
86mm bore and you should be right about that.
It is not the most money effecient way to spend you money as for the gains per dollars. It's somthing different.
Do all that to a dohc vtec 86mm bore with +14.1:5cr race gas and you would see plus 245whp.
Modified by Charlie Moua at 7:43 AM 8/20/2003
race gas
