'01 ITR steering wheel on '94 LS?
I recently picked up a 2001 steering wheel from JDMSpoonITR (Good Seller
It looks like the connector for the SRS is different between my '94 and the '01. I would like to get the airbag operational. I searched and found several references to this problem but no solution. I was hoping someone would be willing to help me out. Thanks!
).It looks like the connector for the SRS is different between my '94 and the '01. I would like to get the airbag operational. I searched and found several references to this problem but no solution. I was hoping someone would be willing to help me out. Thanks!
There is definately a connection problem. I tried to put the steering wheel from my ITR on my '94 GSR but the connections did not work. I ended up using the outer rim of the wheel with the leather wrapping from the ITR with the airbag of the GSR. It feels better, but I really wanted the "A" rather than the "ACURA" on the airbag. I suppose you could splice the connectors from a '98 and up Integ and then connect the airbag. I have not tried this though.
