What's the highest octane gas you've used in your R?
Old Aug 13, 2001 | 11:49 AM
98type_r's Avatar
New User
Default What's the highest octane gas you've used in your R?
We have Vp racing fuel 104 octane for sale at our local track. I've never used anything higher than 92 octane, but I was just wondering... and does it make a difference?
Old Aug 13, 2001 | 11:51 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Re: What's the highest octane gas you've used in your R? (98R)
I've used 100 octane before. The car sounded better, but didn't go faster.
Old Aug 13, 2001 | 11:52 AM
Asahi's Avatar
Default Re: What's the highest octane gas you've used in your R? (newt2)
110
Old Aug 13, 2001 | 11:53 AM
Big Phat R's Avatar
I've run Chevron 94 with NOS boost w/Nitromethane which should bring it up a few points. 104 is killer! I've never tried that high - supposedly it can harm your cat (I run a straight pipe btw).
I've never really noticed any power difference but merely wanted to protect the engine from detonation during hard-use track sessions, hot weather and "just-in-case' I got a bad tank of gas. Cheaper than an engine rebuild.
I DO notice a distinct difference between 91 and 94 though.
Old Aug 13, 2001 | 11:58 AM
Andrew Sites's Avatar
Default Re: What's the highest octane gas you've used in your R? (Big Phat R)
Phatty R,
The only way gas will harm the cat is if it is leaded. If that is the case, you will foul your O2 sensor as well.
Old Aug 13, 2001 | 12:10 PM
98type_r's Avatar
New User
Default Re: What's the highest octane gas you've used in your R? (Andrew)
We don't have Chevron's here in Alberta, so 92 is the highest octane I can get. I've tried the 94 on my road trips and there isn't any difference.
Old Aug 13, 2001 | 12:20 PM
yoshi234's Avatar
I shoot brides
92 is highest ever for my car
yoshi - who can only get 91 gas now
Old Aug 13, 2001 | 12:23 PM
SuspectProduct's Avatar
New User
I've used 112 at the track.
Old Aug 13, 2001 | 12:31 PM
mafay2's Avatar
New User
Default Re: What's the highest octane gas you've used in your R? (SuspectProduct)
My car run nice and strong in Van with 94 octane, but once I drove back to Alberta, I can only get the 92 octane garbage. I have to retard the timing by 3 degree to prevent detonation.
I think high elevation and low octane gas really don't mix well!!
Old Aug 13, 2001 | 12:45 PM
sgT's Avatar
sgT
Default Re: What's the highest octane gas you've used in your R? (mafay2)
high elevation is supposed to act as octane.
What kind of compression are you running that detonates so much on 92?
Old Aug 13, 2001 | 12:47 PM
GRM Scott's Avatar
25 Year Member
Default Re: What's the highest octane gas you've used in your R? (sgT)
D and i were on Sunoco 94 plus a can of NOS octane booster for the track day...dunno what final octane equivalent was. Both ran like champs tho. leaded gas will ***** your catalyst
Old Aug 13, 2001 | 12:58 PM
mafay2's Avatar
New User
I am running around 11.3CR, JDM ITR engine with Spoon headgasket!!
but I think the problem is when I get my ECU reprogram, Yoshio said he can't program the ECU for 91 or 92 octane because of the high CR, so he programmed it for 94 octane gas!!
So I am running an ECu that programmed for 94 octane gas, but running on 91 octane!! My solution? Put a bottle of NOS racing formula octane booster in every tank!! No problem so far! I am too chicken to try a tank without it, so I don't know if it can run without it!!
When i said detonation, it happened when I advanced the timing back to to 15 from 13degree, I can hear some knocking sound at low rpm.
Old Aug 13, 2001 | 01:07 PM
Big Phat R's Avatar
Phatty R,
Are most additives leaded? I heard that the additives (octane boosters) can harm the cat/o2 sensors. There is a disclaimer on the label of the NOS stuff no?
Old Aug 13, 2001 | 01:29 PM
Flux's Avatar
Shell 93
Old Aug 13, 2001 | 01:40 PM
JDM_DOHC_SiR's Avatar
New User
Default Re: What's the highest octane gas you've used in your R? (Flux)
100 Octane all day every day from the pump and 13.3:1 C/R Baby
Old Aug 13, 2001 | 02:55 PM
EVIL CETANE's Avatar
Default Re: What's the highest octane gas you've used in your R? (JDM_DOHC_SiR)
Meathonal/alcohol, VP 18
Old Aug 13, 2001 | 04:26 PM
Yellow Submarine's Avatar
I can tell the diff between Shell 91 and Sunoco 94 Octane. Sunoco all the way
Old Aug 13, 2001 | 05:46 PM
Charged R's Avatar
New User
I run Sunoco 94 octane for daily driver & 100 octane on occasion. You won't see an increase in performance running higher octane unless you advance the timing. Otherwise there's no performance advantage to running higher octane. I treat my ITR with JRSC to higher octane on occasion and a side order of advanced timing.
BTW, I've never had an O2 sensor problem using octane enhancers, but I have destroyed one with Fuel Injector Cleaner.
CivicBoi
52
Mar 6, 2003 08:17 PM
HUBB
11
Dec 14, 2002 07:12 PM
DR3AM
Nov 11, 2002 01:27 PM
vtec.dc2
Aug 22, 2002 02:03 PM
Yellow Dragon
Jan 30, 2002 05:03 PM
