Mounting WW RS Kit on CRX tips??
Old Aug 13, 2001 | 11:37 AM
DevineGSR's Avatar
Default Mounting WW RS Kit on CRX tips??
Can some give me some tips on installing the WW RS Kit on my crx?? What do you guys use to hold the kit on? I dont think that the 2 way tape will hold very well. Also, whats the best way to mold the body kit? I would like to hide all the seams. thanks..
Old Aug 13, 2001 | 09:04 PM
Chris_'s Avatar
Default Re: Mounting WW RS Kit on CRX tips?? (DevineGSR)
follow the directions and the tape will stick.. folow them.. and it will stick
Old Aug 13, 2001 | 11:58 PM
Blown90hatcH's Avatar
Default Re: Mounting WW RS Kit on CRX tips?? (crxconnection)
If you are going to mold it, then counter sink some screw holes on the sides and screw them into the car. Then mold over the screw head. With the counter sinking, you will hardly be able to notice the screws even before the molding.
jason
Old Aug 14, 2001 | 04:56 AM
markedOO1's Avatar
is it a real WW kit? if so, then its urethane and I dont know how good it is to mold urethane since its so flexible. you might be better off getting a fiberglass knock-off.
Old Aug 14, 2001 | 05:49 AM
WuShu's Avatar
New User
Default Re: Mounting WW RS Kit on CRX tips?? (marked001)
Take your time, dont rush, the double sided tape will stick, just use some alcohol on the area on your car to clean it up a bit then wipe it off and it will take to the surface good. Make sure everything lines up btu do realise that urethane tends to warp a bit so it may not line up 100%. It its urethane you cant mold it, the fiberglass will crack off, urethane moves around too much and urethane isnt the most adheasive friendly in the world, but if its fiberglass, just create a small piece of metal , rivet one side to the car and the other side to the body kit, then just fiberglass over it, this will mold the 2 together and give it more strength.
Old Aug 14, 2001 | 06:48 AM
CWBETB's Avatar
My moldings where holding on great till last month. The bottom sections are poping up on the door panels, besides that its still holding on. Interesting note, I heard of someone using windshield repair as a glue to stick them on! Dont know how well this works but its an idea!
crxsi541
Jan 18, 2005 08:07 PM
ImportHatch
Jun 8, 2002 06:55 AM
ImportHatch
Feb 2, 2002 05:07 AM
